It is currently Mon Jun 23, 2025 11:56 pm
 Post subject: Master Cylinders
PostPosted: Wed May 12, 2004 10:40 pm
Apart from the position of the tank to the cylinder is there any differance between the brake and the clutch master cylinders, as in the volume each pumps ?
I wouldn't have thought so as both seem to have the same bore but i want to make sure.
76 1275 Leyland S
PostPosted: Wed May 12, 2004 10:45 pm
Clutch master cylinders are all 0.750" bore (or should be...)
Brake masters varied- original 850 was 0.750", late 998 Cooper was 0.625", all others were 0.700". Many Clubbies had tandem (dual circuit) ones.
Brake masters all have a restrictor valve in the top, clutch ones do not. :wink:
<edit> brake MC sizes above do not apply to late UK imports- I know f'all about them. 8)
PostPosted: Thu May 13, 2004 6:24 pm
In the master cylinders with the metal body plastic tank both the bore sizes are the same, they are exactly the same unit except that the brake master cylinder has a non return valve and the clutch one doesnt. Not to sure about the tin tank master cylinders though?
PostPosted: Thu May 13, 2004 7:05 pm
The new plastic tank type replacement brake cylinders are 0.700" bore.
p/no is GMC171.
Clutch one with plastic tank is 0.750" bore, p/no is GMC1008.
They are not the same but do look it... :wink:
PostPosted: Thu May 13, 2004 8:48 pm
Extract from Gregorys Workshop Manual Pg 131 states, The brake and clutch master cylinders are identical, except that the clutch master cylinder has no non-return valve. Who is right??
PostPosted: Thu May 13, 2004 8:56 pm
They were right back when the 850 was all you could buy....
But, since 1965, (when twin leading shoe front brakes were fitted) all Oz Minis have had a 0.700 bore master cylinder, not 0.750.
This includes Deluxe, Cooper S, Mini K, etc.
late Clubbie brake MCs were tandem, but still 0.700" bore.
Source- Leyland Australia's factory MINI workshop manual (the last one produced here, 1976- still available from Pitstop Bookshop)
My part numbers for the NEW cylinders are from Karcraft's current catalog.
PostPosted: Thu May 13, 2004 9:02 pm
Thanks guys.
I think all that info has helped ?
76 1275 Leyland S
Users browsing this forum: wickedwazza and 103 guests
