It is currently Thu Jun 26, 2025 2:14 am
PostPosted: Thu Jun 05, 2008 8:25 pm
Hi,
I think you can fit R1 carbs to your car with BD10 or 14.
Your car is mk1 Gti so, you have mechanical and vacume adavnce in your dizzy.
You should be able to get 130Bhp from above setup.
I am building similar spec to what I said for my Mini in Uk... kind of stop ATM.
I have following.
R1 carbs with a special cylinder head(P+P).
Suzuki Sports Group A camshaft.
Mk1 Gti gearbox with 3.528 diff ratio and LSD.
Adjustable vernier cam drive
Under drive pulley.
Lightened flywheel
All in chopped and raked Mk2 Mini. with 10 inch wheels.
PostPosted: Thu Jun 05, 2008 9:43 pm
Excellent! :wink:
PostPosted: Thu Jun 05, 2008 9:44 pm
That looks great , what are the wheels ?
PostPosted: Thu Jun 05, 2008 10:50 pm
that chop job is awsome :P :shock:
Mearcat wrote:
PostPosted: Thu Jun 05, 2008 11:36 pm
Thanks guys.
I chopped it by 2 inches and raked front screen by 12degrees to make 45 degree angle.
Back is raked to match front.
I will have Webasto sunroof so all my bad welding will be hidden :lol: !
This is my build diary link.
http://www.16vminiclub.com/forums/viewtopic.php?t=1425
I see so many G13B car in Oz and NZ.
I have managed to convert one of my fellow Mini nut to use G13B when I took him out in my mk1 Swift Gti.
Atchi
PostPosted: Thu Jun 05, 2008 11:56 pm
you should be kept far away from angle grinders lol :lol:
pretty good craftmanship any ways, a lot of work in the bulk head and wat not
cheers dion
Mearcat wrote:
 Post subject: Re: upgrading the G13B
PostPosted: Fri Jun 06, 2008 11:00 pm
Ben_Aus_Mini wrote:
HI
Just wanna know if I replace my G13B Mk1 components in my Mini with
1)adjustable cam gears,
2) a larger coil kit, and
3)a larger (45mm - the maximum) throttle body from the 30mm stock ones.
Could they really improve things much/a lot and also will they have any drawbacks such as shortening the lifespan of the engine, impacting timing and the electircs, etc? And also which of these (1-3) would have a more noticeable improvement in comparison - so that you will definately do first.
I am unsure to how they can replace the cam gears given the extreme tight space in the engine bay. :shock:
For less than $2000 the most sensable mods for a NA G13B are:
Nissan SR20 throttle body
GTI MK3 distributor & ignition unit
Adaptronic ECU (you will also need a MAP sensor & Knock sensor)
Expect over 100HP at the wheels
Blue
Keep shiny side up
PostPosted: Sat Jun 07, 2008 7:54 pm
They're the round shiney metal things with rubber on them :D :D :D
PostPosted: Sun Jun 08, 2008 7:52 am
Bwah ha ha ha - Dicko strikes again! :D
PostPosted: Mon Jun 30, 2008 7:22 pm
umm might want to double check, cause from what I've heard, and having a G13B mini myself, the SR20 TB conversion doesnt really work with the MK1 inlet manifold.
The TB and the MAF are all joined with the MK1's, also the inlet manifold doesnt have as much meat (thick metal) like the later model ones. So cant really grind it much more than 49mm from memory.
If you could find a cultus manifold then the SR20 TB would be no troubles.
best bet would be to fit some bike quad TB set up. get on redline gti and search around for a guy named Tekkie. hes a general font of knowledge.
Torque Steer is a very evil thing. Fun..... but evil.
West Aussie Mini Boys Represent...!!!
PostPosted: Mon Jun 30, 2008 10:30 pm
I have a full set of R1 carbs here if you`re interested
PostPosted: Tue Jul 01, 2008 2:13 pm
redlinegti.com
PostPosted: Tue Jul 01, 2008 4:32 pm
I have a set of of R1 quad throttle bodies & EFI setup if interested.
 Post subject: G13b
PostPosted: Fri Jul 04, 2008 11:48 am
Bullshit! the SR20 TB works perfectly with a MK1 manifold
The TB mounting flanges are identical
Why complicate the issue by fitting quads
Blue
Keep shiny side up
 Post subject: Re: G13b
PostPosted: Sun Jul 06, 2008 4:52 pm
Blue
Whoah easy there fella.
I never said it wouldnt fit. I said the manifold doesnt lend itself to being bored out to the 60 mm size. if you want bang for buck change the manifold then change the TB.
