hee hee, Morris1100, i seem to do that quite often & without even trying
I just priced up the broaching of the mini cam pulley bosses to cut the ket ways & it looks like we are better off just buying the tool & broaching them all ourselves, so i`ve ordered it & as soon as it arrives i`ll get onto doing them,
I`ve just recieved all the dowels for the Bimmer Cam pulley bosses so i can rip in , locktite & punch all those into place, now all we have left is to finish the crank pulley spacers & make all the cyl head plate lower flanges
Once all that lot is done, then i`ll be sitting there for a day or so, setting up all the bolts into their respective cam pulleys & bosses so they`re all bolted together, & then packaging up all the bolts nuts & washers, belts & tensioners, all the plates, flages etc into packets & labeling them all, ,, i still have to "de-dag" (smooth off all the edges) of all the plates etc so people don`t cut themselves while handling them & it`s only a few hours on the router & job done.
& then i just need to add up all what they have cost me, & from what everyoine is telling me i should double that figure & charge them all out at that,,, BUT!!!!!!!!! as i`ve said, i will only be wanting a few kits for myself, so i`ll cost it all up, divide it all by 26 , (30 kits in total, but i want to keep 4 of them) then whatever that price ends up will be what i`ll charge for them
everyone happy with that???
Edit--> Oh & i`ve effectively made up 10x 16v kits & 20x 8v kits & if they all sell out quickly (which going on my pre-orders seems qite likely) then i`ll do another batch & make some money on them, so please do expect the 2nd batch to me more expensive OK?
& don`t forget i have N/A extractors & turbo manifolds & dump pipes allready made up & ready to go too,,,, i`m also working on a batch of water outlets & oil filler/oil drains & breather packages & also top radiator brakets & L/H engine steady bar brakets too ,,, i am also trying to sort some time to make up a lower radiator pipe to fit in-place of the usual lower radiator hose.
it`s all happening boys & girls
no rest for the wicked
