It is currently Sat Jul 26, 2025 11:19 am
PostPosted: Sun May 11, 2008 10:58 pm
what do you mean by if the needles fit? sorry i dont know how needles work in carbies yet
PostPosted: Sun May 11, 2008 11:10 pm
If it physicaly fits into the carb ;)
The working principle is quite easy.
You stick a needle in a hole and flood the hole with gas.
Then you screw that needle onto a piston which raises when the throttle opens and vacuum in the carb changes.
The needle gets thinner and thinner to its tip.
So the more it's drawn out of that hole (which is the jet), the more gas can mix into/with the airstream.
So you chose (or make) a needle which has the right diameter at the right hight to provide the right mixture for YOUR engine.
You sure can make a needle to suit your engine - but that's not an easy job so it'll be very easy to use that carb if the standart SU needles fit.
Erm - hope you understand what i'm writing, my english isn't that good, especially in technical terms :lol:
Jan
PS: thats the basic principle of an SU, there are more influencies to mixture like damper, piston springs.
PostPosted: Sun May 11, 2008 11:13 pm
You're making perfect sense jan , love the image of the SU working by the way , might have to use that myself to explain them to people ass a lot can't grasp the idea .
PostPosted: Mon May 12, 2008 8:18 am
Oh ok, My friend said that the jets have been replaced or something. How do i know what needle is for my engine?
PostPosted: Tue May 13, 2008 10:16 pm
Asphalt wrote:
why do I find that animation erotic?
PostPosted: Tue May 13, 2008 10:27 pm
I is a mookenik
i was waiting for someone to say that....you put the needle in the hole?
PostPosted: Tue May 13, 2008 10:33 pm
Jan,,, you have done exceptionally well,,, the best/easiest i`ve ever seen/heard it explained,,, well done
& Simon,,, you`re not the only one :-) i love cartoon sex,,, oops,,, er,,, um,,, did i say that out loud ??? :-)
PostPosted: Thu May 15, 2008 7:22 pm
will i just need to buy a needle to suit my engine and fit it, or do i need to make any other mods to the carb?
PostPosted: Thu May 15, 2008 7:38 pm
Forum Graffiti
Have you got a normal SU needle lying around, or from your other carb? If that fits into one of those, yes, just buy a needle to suit.
PostPosted: Thu May 15, 2008 8:17 pm
can i use the needle thats in my 1.25" carb in the 1.5" or do bigger carbs have different needles
PostPosted: Thu May 15, 2008 8:21 pm
Forum Graffiti
Good question! :lol: IIRC they all have the same needles... someone care to verify. I haven't tried different needle/jet combos :?
PostPosted: Thu May 15, 2008 9:25 pm
The 1.5" needles are bigger. The main drama might be the design in which the way the needle fits the piston in the Jap instrument. Midel may have a conversion kit, same as when you change the spring loaded 1.5 needle to fixed needle in Mini HS4's - You may be lucky.
PostPosted: Thu May 15, 2008 9:53 pm
so i will have to go out and buy a needle
PostPosted: Thu May 22, 2008 8:28 pm
Hey Pete - have you breathing too many of those tile glue fumes???
HS4s are 1.5s .??.. and 1 1/4s and 1 1/2s both use 90 thou jets and hence the same family of needles (albeit different needles due to the different air flow each type provides). The conversion kit to change fixed to floating needles is a simple holder that costs a few $$ (I think my last ones cost less than $5 each.
One of the SU catalogues should identify an appropriate needle for a stocko 1.5 equipped 1100.
Cheers, Ian
PostPosted: Thu May 22, 2008 8:39 pm
Cheers, Ian
Vizard is suggesting M1 or BQ, but for a datsun carb, who knows...
but cookie, I reckon you're nuts using one when you can get proper 1.5" SU's for nothing...
