It is currently Tue Jul 22, 2025 11:25 pm
 Post subject: wedged stroker crank
PostPosted: Tue Apr 29, 2008 10:00 pm
Have got a unassembled stroker motor does it need wedging for an occasional driver
it will be balanced regardless
PostPosted: Tue Apr 29, 2008 10:01 pm
i wouldn`t bother if it`s just a roady/club race donk
PostPosted: Tue Apr 29, 2008 10:35 pm
I reckon it will run smoother if you do it- and the main bearings should last longer too.
Big journal 1275 crank has lousy counterweighting, this is accentuated by stroking.
My 1412 stroker ran as smooth as on the engine dyno, after I wedged it. :D
PostPosted: Wed Apr 30, 2008 1:52 am
mine too :D
PostPosted: Wed Apr 30, 2008 9:14 am
And mine :P :lol:
PostPosted: Wed Apr 30, 2008 4:02 pm
wedging is?? :oops:
PostPosted: Wed Apr 30, 2008 4:48 pm
Trimming excess metal off the rounded counterweight parts of the crank.
I don't know the orign of the term wedging (in relation to cranks :D ), but the ones I've seen end up being a bit triangular in shape, so maybe the "wedge" comes from that.
That'll do until Doc comes in and explains in proper engineer terms.....
KB
PostPosted: Wed Apr 30, 2008 4:50 pm
Wedging is removal of metal from the crankwebs on the side nearest each crankpin.
This has the same balancing effect as making the counterweights bigger, but it also reduces the rotational mass (inertia) of the crank.
Here's some pics of mine- I did it at home on the mill then got GR to balance it.
<edit> that centre main strap in the last pic I made too, it's EN25, tuff stuff- made to fit the near-standard bearing cap without milling it flat (and thus weakening it). Bolts are Grade 8 hi tensile.
Last edited by drmini in aust on Wed Apr 30, 2008 5:00 pm, edited 1 time in total.
PostPosted: Wed Apr 30, 2008 4:58 pm
So the term "wedging" comes from.........????
Cmon Doc, you're letting me down! :lol:
KB
PostPosted: Wed Apr 30, 2008 5:01 pm
Look at the 2nd pic, it looks like a wedge.... :lol:
PostPosted: Wed Apr 30, 2008 7:15 pm
make sure you also rebuild your harmonic balancer or get a new one. will help a lot to minimise harmonics that these cranks suffer from.
PostPosted: Wed Apr 30, 2008 7:19 pm
Also, lightening the flywheel assembly will reduce and move the harmonics further up the RPM scale.
PostPosted: Wed Apr 30, 2008 8:11 pm
This be moine
PostPosted: Thu May 01, 2008 8:17 am
Dr Mini, That Centre main strap looks great. I always wondered why, when the idea is to add strength to the centre cap, you have to mill some off to add a strap.
Any chance of you running off a few to sell to us more technically challenged?
PostPosted: Wed May 07, 2008 11:00 pm
stocko small journal
smallblock stroker crank (1100)
