It is currently Fri Jul 18, 2025 8:03 pm
 Post subject: Rocker ?
PostPosted: Wed Apr 23, 2008 7:15 pm
I have a set of 1275 rockers with the oval pads and would like to know if they will fit on a small bore motor?
Cheers Pete
PostPosted: Wed Apr 23, 2008 7:23 pm
Yep.
PostPosted: Wed Apr 23, 2008 7:26 pm
Thanks Mick. Are they a straight bolt on do you have to anything?
Cheers Pete
PostPosted: Wed Apr 23, 2008 7:32 pm
No, straight over.
PostPosted: Fri Apr 25, 2008 1:53 pm
If they have a flat washer next to the exhaust rockers, remove them for a smallbore. The valve spacing is a bit different.
