It is currently Thu Jul 10, 2025 10:17 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Dec 26, 2007 11:29 am
[/quote]
precis please. :o[/quote]
Doc, you are excused. My comment wasn't for you.
PostPosted: Wed Dec 26, 2007 11:45 am
It's only the 2 tanks that are brass- the rest is copper- that's where the heat is dissipated.
Bling the top tank if you want... it won't make any difference. :wink:
So does that mean I can paint it without and adverse effects?
blokeinamoke wrote:
PostPosted: Wed Dec 26, 2007 11:56 am
Mokesta, you'll have to do better than that....
PostPosted: Wed Dec 26, 2007 12:32 pm
You can paint the tank or not, it won't matter.
I wouldn't paint the core, beyond the mist coat of black that radiator shops put on them.
PostPosted: Wed Dec 26, 2007 1:26 pm
Well they don't paint the new age aluminium radiator cores if they can help it either...
Mind you, the older copper cores would look pretty crap with the lead solder and flux marks and the fact that it would turn green after a while. Even the top tank can look pretty ordinary bare unless there's been a neat job of soldering it on.
If there was any reason for painting a radiator, this would be it, and if you were going to choose a colour, then black would probably be the best case for the technical reasoning above.
PostPosted: Wed Dec 26, 2007 2:25 pm
thanks guys.
I really only wanted to paint the tanks anyway. They are now painted gold and the core is bare copper.
Will the core go green if I dont paint it? And is bare copper better at radiating heat than copper that is painted black?
what I am getting at is, in painting the core black am I also insulating it and reducing its ability to radiate heat?
blokeinamoke wrote:
PostPosted: Wed Dec 26, 2007 2:47 pm
It depends what you paint it with. Anything beyond a thin mist coat will reduce heat transfer. I would NOT use enamel, it piles on too thick.
My choice would be a can of VHT brand black acrylic. :wink:
PostPosted: Wed Dec 26, 2007 4:42 pm
Use whatever the matterial requires to promote heat transfer. Remember you are heating the air no cooling the coolant, the coolant is only the transfer medium for the heat to leave the system - you also want to keep some of it in the system.
The harder it is for the heat to leave the more power you loose.
Copper is different beasty and you need the paint to stop the insulating oxidising layer you get on copper which insulates - unless you want to spend your life polishing the thing. So the correct paint in small amounts promotes heat exchange on copper.
PostPosted: Wed Dec 26, 2007 5:00 pm
Way back about 20years when I was looking and making some solar panels (had them made in the end) I found out the best surface treatment for solar collectors was a chemical reaction that made the copper black (hydrogen sulphide I think - may be wrong but) That way there is no insulation effect of the paint. More fiddly - thats why the commercial units are painted :?
David L
PostPosted: Wed Dec 26, 2007 5:54 pm
Rheem (and most other) copper sheet and tube solar collector panels these days are not painted, they are plated with a black `selective surface'. This admits solar heat in at a much higher rate than it radiates it.
Not much good for a radiator though! :lol:
<edit> I know this `coz I've worked at Rheem's factory for 30+ years. :wink:
PostPosted: Wed Dec 26, 2007 8:28 pm
paint it on backwards
PostPosted: Wed Dec 26, 2007 8:42 pm
Look,,, it really doesn`t matter what colour you paint your radiator, that`s got virtually nothing to do with it`s abilty to cool your engine,---> "IF" your engine heats up to the point where it runs "TOO" hot, then rest assured that it won`t be the paint that`s causing it & there will be another dam good reason why it`s running hot,
that`s a fact!!! so paint it whatever colour you like, leave it unpainted & even pollish it if you want, it`s a matter of whatever you think "LOOKS" good, because your mini just simply won`t over heat "BECAUSE" you`ve given it a light coat of paint
the only way that i can see paint on a radiator to "CAUSE" problems is if you coat it so many times that you block the fin air area & that would just obviously be stoopid
& anyways, there`s not many radiators out there that can cool as good as my alloy ones & i don`t paint them either :-)
sorry, but crickey, all this mumbo jumbo about what colour cools better & such just eats me up, what`s a degree or 2 btween friends hey?
PostPosted: Thu Dec 27, 2007 5:59 pm
Mokesta?
PostPosted: Thu Dec 27, 2007 7:10 pm
I Here You Matt
If you are worried about the colour of the Paint regarding to the Rention or Exposure to Heat you have bigger problems in your Cooling System
Its not the roof of your car :roll:
PostPosted: Thu Dec 27, 2007 7:51 pm
A lot of people say that the radiator on a Mini is only just up to the job of cooling a Mini. If the colour of the paint can make only a degree or two difference why would you not take advantage of it?
