It is currently Sat Jun 28, 2025 5:00 pm
Post new topic Reply to topic  [ 305 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 21  Next
PostPosted: Tue Dec 04, 2007 8:30 pm
wow looks hawt!!
what hp are you expecting?
 Post subject: mmmmm
PostPosted: Tue Dec 04, 2007 8:50 pm
i so want one.... please santa please......
i like to drive on rails
PostPosted: Tue Dec 04, 2007 9:25 pm
ausmini mod
ausmini mod
albino235 wrote:
I agree... videos and get a dyno sheet up too :D
Didn't go on the engine dyno... sorry.
Next dyno day, ill be there.
Pete.
PostPosted: Tue Dec 04, 2007 9:27 pm
ausmini mod
ausmini mod
DTrain wrote:
wow looks hawt!!
We guess its putting out about 110-115 at the moment easy.
Will go on rolling road at some stage but thats not really accurate
Pete
ausmini mod
ausmini mod
gafmo wrote:
Well done Peter and Ben nice work..peter you'll have to take me for a spin :wink:
Anytime Jimbo ;)
PostPosted: Wed Dec 05, 2007 7:50 am
What about me Pete?
PostPosted: Wed Dec 05, 2007 8:50 am
ausmini mod
ausmini mod
willy wrote:
What about me Pete?
willy, you'll get a ride... then sumtin' sumtin' when we stop for a breather ;)
You coming to the drags next time Chris organises?
Pete
PostPosted: Wed Dec 05, 2007 9:15 am
I'd love to... in my own car this time.
And with proper tyres.
Should see a bit better time too... especially with a proper diff :lol:
PostPosted: Fri Dec 07, 2007 8:53 pm
ausmini mod
ausmini mod
More pics with water cooling hooked up on turbo and filter setup
Sorry about quality, I use my phone, the good camera needs to stay away from oily direty hands... Ill get some nice ones soon
Pete
PostPosted: Fri Dec 07, 2007 9:10 pm
:shock: That's one big air filter.
2008 Prado GXL
PostPosted: Fri Dec 07, 2007 9:30 pm
Are pod filters still legal, I was told Da Fuzz was jumping on these for defect fodder?
Maybe only with the riceboys... :wink:
PostPosted: Fri Dec 07, 2007 9:55 pm
not exactly sure but in qld you need the air filter enclosed otherwise defect
PostPosted: Fri Dec 07, 2007 10:47 pm
ausmini mod
ausmini mod
Its enclosed in my engine bay haha.
If a cop pulls me over, ive been doing something stupid in the first place...
If I need to enclose it, I will... but for now, its staying as is.
Fat Boy Dave - Yep, its overkill and prolly bigger than needed but its a washable really really strong, well built filter so I thought, why not.
I needed something asap - and this was the best quality I could get that I could mount at work in the carpark :-)
Peter.
PostPosted: Wed Dec 26, 2007 8:28 am
ausmini mod
ausmini mod
Well, time for a bit of an update.
Things were going well... but had some 'issues' :)
First thing was going up a hill at Castle Hill... nailed it and oil pressure dropped to 0
Oil friggin EVERYWHERE...
Turns out the oil return from the turbo split and dumped all my oil.
A new hose and a few scratches later it was all back to working fine.
Next thing was my head mods.
The head has been extensively worked by GR but with the roller tipped rockers on didnt have enough lift. The rocker angle was really bad and the rockers needed to be raised.
Dr Mini made me some spacers 2mm thick and we set those up and things were a bit better, but rocker angle still bad... it started to chew the top of the valves up pretty bad.
Thought I would leave it a little longer for now, but Jenna decided she wouldnt have it.
Blew the exhaust manifold gasket on 1st and 2nd ports and was farting around.
So, off with the turbo parts and head for work.
Installed a new exhaust Manifold gasket (but the metro turbo one with metal backing - nice :D)
Head was off, so fixed the valves at GRs and then decided to sort out the geometry.
GR said it needs more packing, in the end, it needed 5mm under the rocker posts to get the rockers to move correctly and sit right.
Now, as you may have guessed already that much spacing causes other issues.
First, I put the head and rockers back on, and the pushrods couldnt reach the rockers :(
Ok, well, this 1100 needs 1275 pushrods :)
Put in 1275 pushrods, adjusted everything and bolted everything together...
BUT, its never that easy... now the 2nd rocker actually fouls on the rocker cover- there is a plate under the breather and it hits there... enough to lift the rocker cover up and down :)
Two gaskets or mods to the cover will fix that...
More info soon...
Pete
PostPosted: Wed Dec 26, 2007 10:04 am
Give Ash some flowers Nick .
Geez Pete :shock:
That is so increadibly neat compared to the turbo set ups I see in magazines! All the others have pipe work going every where! I like it. 8)
