It is currently Wed Jul 09, 2025 10:54 pm
 Post subject: Compression ratio
PostPosted: Tue Nov 20, 2007 8:50 pm
Hi guys
I am having trouble finding in the yellow book what the chamber size (only) needs to be on a 1098+.60 to give an approx ratio of 10.5 - 1
I have done some looking on line and from what i can gather I need a 14 cc chamber volume. That sounds pretty small.....
any ideas?
thanks :D
blokeinamoke wrote:
PostPosted: Tue Nov 20, 2007 9:01 pm
This space for rent
14cc may sound small, but that's only in the chamber. How much extra will you get in the gasket and piston dish? 6cc? 8cc? Does that add up to something approaching the right number.. ?
PostPosted: Tue Nov 20, 2007 9:08 pm
yeah it looks better, the gasket etc etc accounts for about 15cc.
Will keep digging
thanks mate
blokeinamoke wrote:
PostPosted: Tue Nov 20, 2007 9:36 pm
PM sent.
PostPosted: Tue Nov 20, 2007 9:42 pm
a 14cc cyl head is REALLY dam small & no matter what mini engine i`d "guess" that`s way too small
PostPosted: Wed Nov 21, 2007 7:03 am
OK this is what I think I know.....
my total capacity for 1 cylinder is 288cc so i devided that by 10.5 and I got 27.4
SO I am guessing 27.4 is my total chamber volume(ring land,gasket,piston to deck clearance)
so,
using your numbers as a guide,
- 3cc gasket
- 8cc for piston dish (I am using hypertecs too)
-1 cc for the piston to dec clearance
so therefore my chamber volume in the head alone should be
27.4cc - 12cc = 15.4 cc??
Unless of course I am an idiot and its all wrong :?
PostPosted: Wed Nov 21, 2007 7:30 am
To work out the total combustion chamber volume divide the cylinder capacity by ONE LESS than the desired CR
So for 10.5:1 divide 288 by 9.5 equals 30.3 total chamber volume
Hope this helps
PostPosted: Wed Nov 21, 2007 5:33 pm
yes it does mate, thanks
18 cc sounds doable, maybe. with all the deshrouding I have done the chambers are farily big.
still bloody small tho
blokeinamoke wrote:
PostPosted: Wed Nov 21, 2007 6:29 pm
14cc it's strange, because the nominal volume is 24.3cc as the 998 and 21.4cc for a 12g940.
which cylinder head have you got? because with 14cc, you should have a cr of 14 not less.
if you buy your piston from the minisport shop send a mail to andrew.
for me these piston should give 9.6 or 9.75.
a 998 with flat piston gives 10.3.
www.moroccominiraid.blogspot.com
PostPosted: Wed Nov 21, 2007 8:46 pm
its a 12g202
How much has anyone been able to mill off these things?
OR should I get the pistons squared off and have the block decked?
blokeinamoke wrote:
PostPosted: Wed Nov 21, 2007 8:51 pm
actually I think I might go and drink some paint :x
blokeinamoke wrote:
PostPosted: Wed Nov 21, 2007 8:56 pm
mini-dunger wrote:
its a 12g202
The more you take off the more gasket probs you can have.
Having said that, Gafmo's has has about .090" off I think...
:shock: :lol:
Yes that's a possibility but talk to GR. :wink:
PostPosted: Wed Nov 21, 2007 10:01 pm
:lol: havent had a gasket for some time now
PostPosted: Thu Nov 22, 2007 6:51 am
what do you mean by havent had a gasket??
I should have picked up a 1275 head in the first place. I have spent $300 so far on this piece of crap,plus about 3 weekends. And now I am left with something that more or less makes the whole motor worth no more than a piece of crap. Mr V said getting compression up after all this deshrouding and such would be no problem.... well it bloody is.
I have 2 options as far as I can see, well 3 kinda...
1Flat top pistons (if they fit,cause its bored .60 for my hypertecs)
2get 3mm or so milled off my hypertecs to reduce the dish cc, then get the block decked to suit.
or get about 4mm milled of the head :? :?
If the piston dish cc was out of the equation I wouldnt have to skim the head to death and it "should" survive.
Im am so close to having this built yet so far...
end rant :arrow:
blokeinamoke wrote:
PostPosted: Thu Nov 22, 2007 8:47 am
Give Ash some flowers Nick .
I think gaf means that he hasn't blown a head gasket recently.
Correct me if I'm wrong gaf :)
