It is currently Tue Jul 08, 2025 11:38 pm
Post new topic Reply to topic  [ 103 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Sat Oct 27, 2007 7:11 pm
Besides, I already have one...
That's the best reason for using anything i reckon. Why spend when you can save :wink:
Will it be worth modding the float bowl ala GR's HS? NOt that i can see wendy ever needing more fuel going off to the shops to do the shoppping. But maybe to save detonation of a motor if she gets an itchy righ foot.:lol:
Aaron
PostPosted: Sat Oct 27, 2007 7:23 pm
Yes Aaron, I'll get GR to GR the floatbowl... and the van will be getting a new 5/16" fuel line when I convert it to hydro luxury.:wink:
PostPosted: Sat Oct 27, 2007 7:24 pm
I love hyrdo :)
PostPosted: Sat Oct 27, 2007 7:25 pm
aaron wrote:
I love hyrdo :)
I want it to ride civilised, like a Morris 1100. 8) :lol: :D
PostPosted: Sat Oct 27, 2007 7:26 pm
What does Graham do to the float bowl?
I have three 48mm Dellortos, I really should build something to go with them. :lol:
PostPosted: Sat Oct 27, 2007 7:32 pm
I believe he drills out the float valve or something, going on what I've heard.
PostPosted: Sat Oct 27, 2007 7:33 pm
Has anyone ever tried running an a series backwards? YOu know 3 dellorto's up the exhaust, reverse the firing order and open pipes out the inlets..... Yeah dumb idea.... but wouldn't it be a great you tube video :lol:
PostPosted: Sat Oct 27, 2007 7:34 pm
That was a common mod with Ford 100E motors. It worked. They had 4 exhausts though.
PostPosted: Mon Oct 29, 2007 6:31 pm
OK I've pulled the head off again as it makes it easier to invert the motor and drop the gearbox on.
Here's pics of the 12G1316 (off 1275 Moke) head.
Valves are MK2 S. Head is ported by me a la Vizard, I even hit water where he says you do. :lol:
Valve springs are Minispares C-AEA526. 1.46:1 rockers by Mr Toyota.
PostPosted: Tue Oct 30, 2007 1:56 pm
Give Ash some flowers Nick .
That is yummy! I wish my head looked like that. I can't wait to see the numbers it throws up on the dyno.
PostPosted: Thu Nov 01, 2007 9:25 pm
That head above has about 50 or so hours of my time in it, mind you I did it years ago when my eyesight was better!
Here's another 12G1316 I've just tickled up for my 1132 Moke, which will have the block notched to suit-
PostPosted: Fri Nov 02, 2007 6:41 am
Doc what you need is one of those CNC Mills. Bolt the head in, turn the computer on and walk away :D
Serious question - can you set the computer on those by scanning a head that has already been ported?
KB
PostPosted: Fri Nov 02, 2007 8:58 am
KB
In simplistic terms, yes, you can scan a 3d object with a laser scanner, convert it to CNC instructions and set the mill to do as many copies as you'd want. In practice its a bit more involved than that, but once you have it set up and save the instructions, you can just churn them out like sausages.
You might still want to hand finish them, to keep the non-believers happy.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Nov 02, 2007 10:13 pm
Timbo wrote:
KB
Not only that it also the Expence for some one to do the Numbers
The Machine may cost $$$$
but also the labour to add in the numbers :?
If you were to go to this extent you would have to think of the amount of heads you would need to do and the amount of proffit from the Complette total
this is why the 7, 8 port heads and the 5 gearbox (not exactly) are not readly avalible now,
50 Hours to most people that require a result is nothing except your own time
PostPosted: Sat Nov 03, 2007 5:46 am
I doubt you would do all up inside the A series ports on a CNC mill without lots of hand finishing.
Chambers yes, and the ends of the ports, no problem. :wink:
