It is currently Fri Jun 27, 2025 2:26 am
PostPosted: Mon Sep 24, 2007 12:59 pm
Sorry to post this if it's a regular thread but I'm too lazy to search.
I've found an engine I want to put in my car, aside from that, the car cost and the usual suspects of rego, blah blah blah, what other expensive factors should I need to be aware of? EG What would engineering cost roughly, and what else could I be up for?
Thanks.
:D
PostPosted: Mon Sep 24, 2007 1:29 pm
If you are confident you can keep it stock....
Engineering ~$800up
What Motor?
Have you got the frame sorted out?
Depending on the motor you chose a brake upgrade..
PostPosted: Mon Sep 24, 2007 3:01 pm
Engine I'm looking at is a JB-DET from a Daihatsu Copen.
I dont have it yet, so no subframe.
As for brakes I have a few sets of 8.4 solids, some metros and if I get carried
away I'll look at four wheel setups.
I just figured I should look at the costs before I commit to an engine.
PostPosted: Mon Sep 24, 2007 3:22 pm
it's quite a small motor, i would really look at weighing the benefits againsts the cost vs going something like a well built turbo a-series..
There was a Copen at our dyno day, owned by Justin and it made 56HP at the wheels with an upgrade kit.
Look at where it sits below compared to all the A-Series..
My NA Small Block made more power...and that's reliable, driven it to Melbourne, Track Days, etc...
IMO i wouldn't go near the hassle of a conversion for only that much gain when there is nothing wrong with a good A-Series. Conversions are only really practical when you want over 150HP
PostPosted: Mon Sep 24, 2007 3:32 pm
I'm looking at it based on a cost thing.
I have 2 a series engines and each could do with a full rebuild.
I don't want to spend that money on both, and for a similar cost to a rebuild
I can have a near new jap engine in the car.
I'm yet to make a final decision, just need to add up all my options.
Thanks.
PostPosted: Mon Sep 24, 2007 3:52 pm
You got the engine - a rebuild would cost what...$3-5k TOPS for something really good with decent power.
With Conversion:
- Subframe could cost anything really...$1000 for a rough guide
- Engineering $800
- Insurance Increase.
- Drive Shafts. ~$500+
- Fuel Tank + Lines for Fuel Injection
- Fuel Pumps
- Miscellaneous Custom Work for Gear Linkages, Cluch etc.
- Plus Motor, Brakes etc that are common to both.
Whatever you think it's going to cost. Double it.
PostPosted: Mon Sep 24, 2007 4:23 pm
At a minimum double it....
Life's a garden.... Dig It!
PostPosted: Mon Sep 24, 2007 4:24 pm
:lol: Triple Double.
PostPosted: Mon Sep 24, 2007 4:25 pm
I gurantee you an A-series with the same power output as that motor is a much more cost viable option.
PostPosted: Mon Sep 24, 2007 9:40 pm
Alright I heard somewhere that 1.6+forced induction or 1.8 N/A is the limits of what we can put in our minis, correct?
Why arn't their many of these getting around? everyone seems to be doing 1.3 turbos :? Shorley theirs more power in these bigger engines.
PostPosted: Mon Sep 24, 2007 10:05 pm
bigger donks usually weigh more, and are a larger size eg. a 1.8 vtec is taller then a 1.6 vtec and requires it to sit lower in the subframe to clear the bonnet.
besides its always fun to squeeze out power from the underdog smaller engines. if i was doing a conversion i'd be looking at a well balanced car, enough HP that you could use in conjunction with good cornering. i'd learn towards a 4efte, around the same weight as a A series, small capacity (fuel economy)
my 2c
PostPosted: Tue Sep 25, 2007 3:06 pm
4EFTE?
For me, because ther is already one on the road here in SA, and I'm good friends with the very talented bloke who built it.
I'd probably prefer a Honda 1.8, or even K20, but I think that's going too far.
The stock 4EFTE makes good power, you'd have a 100kw Mini and reliability as the motors stock, that's what I'm going for. Band for buck it won't be worth it but, I'll have ~95 hp atws, great fuel economy (compared to a turbo A series of the same output) and great reliability. Although it won't have that tough A-series sound anymore. :cry:
PostPosted: Tue Sep 25, 2007 7:24 pm
The regs are that... For turbo or super charged its 2.5 x the ORIGIONAL tare wieght. For naturally aspirated its 3 x the ORIGIONAL tare wieght and they'll give you an engine capacity in cc's. I dont know about you but the weight i found for my van was 597kg and that was the lightest wieght i could find even though the heaviest noted wieght was only like 20kg more (fuel??) 2.5 x 600 gives you 1500cc for turbos and 3 x 600 gives you 1800 for naturally aspirated
thats my 2c worth
PostPosted: Tue Sep 25, 2007 7:47 pm
As far as I'm aware, the cc's related to car mass is not a part of SA law, there is much info on engine changes but they come under different catagories.
Has the law changed, or is SA just behind ( 8) )?
PostPosted: Fri Sep 28, 2007 7:35 pm
thats my 2c worth
Gordo,
When I quizzed my engineer on this, he used kerb weight, not Tare!
So, the figures I was told was 1600cc max for forced induction, and 1950cc for N/A.
Tricky
