It is currently Thu Jul 10, 2025 2:01 pm
PostPosted: Sat Jul 28, 2007 5:37 pm
See this mini for sale on ebay. Widened and lengthened. Why? Its not like a mini doesn't have the space.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... otohosting
67 Deluxe under going full resto
PostPosted: Sat Jul 28, 2007 10:56 pm
What a lot of work, I wonder what he was going to do for a windscreen?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sun Jul 29, 2007 8:50 am
a 6 inch central pillar. :?
PostPosted: Sun Jul 29, 2007 10:45 am
There are at least another 3 threads about this car, was on ebay a few weeks ago.
If you buy it, you'd be buying it just for the GTi parts, the Mini is just scrap metal value.
PostPosted: Sun Jul 29, 2007 11:02 am
you'd have to make a custom bootlid,grille,bonnet,headlining,carpet,seats,dash,windscreens......the list could go on
 Post subject: Ewwww
PostPosted: Sun Jul 29, 2007 11:55 am
3 inch blind spots either side might be better :?:
PostPosted: Sun Jul 29, 2007 5:30 pm
You could always cut two windscreens three inches off centre and just use the two wide bits with a join up the middle. 8)
 Post subject: Large Mini
PostPosted: Sun Jul 29, 2007 5:38 pm
and call it a Morris Oxford :!: :idea: :lol:
 Post subject: Re: Large Mini
PostPosted: Sun Jul 29, 2007 6:14 pm
These days you just use a bead of clear silicone to join the two bits, you have to look harder to see the join.
PostPosted: Sun Jul 29, 2007 7:16 pm
sticky tape does wonders :P
 Post subject: make a buck
PostPosted: Wed Aug 08, 2007 9:09 pm
You'd have to make a ply buck then cover it with sheet metal, lay some flat glass on it and heat till the glass relaxes over the buck.
I was told this by an ex ferarri coach builder, still cant figure how the rubber in the laminate holds up to the heat?
