It is currently Mon Jul 07, 2025 7:07 pm
 Post subject: Brakes need bleeding?
PostPosted: Sun Jun 24, 2007 8:14 pm
Hi,
I've almost got my 71 clubby roadworthy, but the brakes are VERY spongy. As in 3 pumps, before they work. Now I've got a fair idea that I need the brakes bled. Thing is, I have limited tools and no real idea what I'm doing :lol: Is there anyone in south east melb who either can do it for me (for a price of course) or know someone who can? Any help would be greatly appreciated. Thanks again.
J
p.s. Actually make that 2 clubbys who need brakes bled at my house :(
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Sun Jun 24, 2007 9:03 pm
is the pedal spongy after you pump it three times or is it firm?
if its spongy you're in trouble,
if its firm you just need to adjust it, which you can do with the correct sized spanner and 10 minutes.
PostPosted: Sun Jun 24, 2007 9:06 pm
hey man, nah its firm after the 3rd pump. If the pedal travel was 3 times longer, it would be fine :D Just seems to take ages to pump up enough pressure. And as soon as we let the pedal off, its back to pumping 3 times to stop. Almost ran into my own garage door :oops:
PostPosted: Sun Jun 24, 2007 10:02 pm
Slow-Po
I've had the same problem, caused by leaky wheel cylinders.
PostPosted: Mon Jun 25, 2007 7:48 am
Check your adjustment before using brake fluid
