It is currently Tue Jul 22, 2025 3:28 pm
 Post subject: Drive shaft question
PostPosted: Fri Jun 08, 2007 10:08 am
Hi all
I was just wondering if it is possible to fit the drive shafts after the hubs have been fitted? I was thinking I could pack the CV's with grease then cover them with plastic and a cable tie. I just didnt really want them flapping around in the engine bay when I push it around incase the ball cages got damaged.
Thanks
blokeinamoke wrote:
PostPosted: Fri Jun 08, 2007 10:28 am
Why not just replace the hubs temporarily ie leave the ball joints/tie rods loose until your'e ready to install the shafts. The weight of the car will keep it all together while you move it around. :idea:
PostPosted: Fri Jun 08, 2007 10:39 am
i have a old set of cvs with no shafts so i can move the minis or choke around
