It is currently Sun Jul 20, 2025 10:32 am
 Post subject: Lights problem
PostPosted: Tue Jun 05, 2007 11:27 am
Doing some work on the interior of the mini, and accidently turned the lights on. Noticed the gauge lights didn't come on. So i turned it to headlights, they worked, no gauge lights. Turned to high beam, the high beam worked, still no gauge lights.
Turned back to normal headlights, no lights at all. H beam still works.
I have Halogen lights with a NEW ERA relay.
Apart from taking to a sparky, what do i check?
Matt
PostPosted: Tue Jun 05, 2007 11:31 am
I want to have Al's babies
Earths. 8)
PostPosted: Tue Jun 05, 2007 11:41 am
i drove for weeks (and i work nights) without gauge lights before i figued out that i just bumped and turned the dimming switch. do u have one of these?? or maybe ur not as stupid as me haha :wink:
steve
PostPosted: Tue Jun 05, 2007 11:49 am
i had a similar problem, lights fine, but for some reason my gauge lites didnt work. used the light from my phone to check everyhting every couple of minutes. but the problerm has rectified itslef, plus i ahve my interior lioght and horn back...
so my suggestion is - don't check anything, it will be right :D
78 Leyland Mini - Prince
PostPosted: Tue Jun 05, 2007 11:52 am
Could possibly be a fuse going on the blink...?
PostPosted: Tue Jun 05, 2007 11:59 am
No, they're not particularly cunning these ones. They feed off the park lights connection on the back of the light switch so check the connection there, and they earth in the back of the instruments for a centre speedo, not sure on the clubby.
PostPosted: Tue Jun 05, 2007 3:19 pm
Thanks everyone, I did the round of checking all the wires etc, and found a loose connection. I have a switch to turn the gauge lights off for stealth mode. I haven't used it for years and now basically use it as a junction box. This had a wire knocked off. Fixed it up and it is all good!
Seemed bad at 2am this morning!!
Matt
