It is currently Mon Jul 07, 2025 10:45 pm
 Post subject: Half cage installation
PostPosted: Sat May 12, 2007 3:50 pm
here are a few pics of putting in a half cage from bonds bars. it's a fair bit of work. only the hoop is in for the photos. the rear leg have been set up, tacked and removed for welding but i haven't put them back in yet.
here is a pic of where you have to cut the rear pocket
PostPosted: Sat May 12, 2007 4:37 pm
looks good. i know your pain, as my six point is same design but with the front legs and door bars.
PostPosted: Sat May 12, 2007 5:30 pm
did you have anyproblem with clearance at the top of the passenger side angle on the bottom bolt hitting the diagonal in the hoop
PostPosted: Sat May 12, 2007 9:02 pm
just made it fit at the right angle. it sits a bit further inboard to avoid that problem, and i also mounted it up with the bolt and slid it as far outboard as possible after the bolt was in there. that way you dont need a lot of room to insert the bolt if you have already bolted the wheel arch end down.
michael
PostPosted: Mon May 14, 2007 9:26 pm
the cage has been removed and painted and is back in now i didn't get a chance to take pic and my little brother took his camera away with him. will post some pics when he gets back
PostPosted: Tue May 15, 2007 6:33 pm
Great pics stuart looking at doing the same to my clubman.Why are you only putting a half cage in and not a 6 point
PostPosted: Wed May 16, 2007 9:33 pm
i only went for the half cage because in nsw you can't register it with a six point, i might by the front arms later and only put them in for track days. here are the rest of the pics.
and this is what i want my car to be like but without bumpers and a bmw head instaed of 8 port
