It is currently Mon Jun 30, 2025 11:12 am
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 125  Next
PostPosted: Thu Feb 08, 2007 7:29 am
Yes mate,
Spot on!!
Thought about going the internal hinge route, but then thought hey, its about time to finish it and stop adding stuff - maybe on the next one!
It does have a gas strut though - its off a Toyota Camry I think. It automatically pops open the boot lid when the release is engaged, then opens nice and slowly until full extension which is the same distance as normal boot lids.
Let me know how yours goes...
Tricky
PostPosted: Sat Mar 03, 2007 10:51 pm
CHAPTER 15 - Still More Bodywork
Hi Everyone,
I guess its time for an update. Work has been progressing slowly but surely on El Gato, and we are still working on the bodywork. It seems never ending. Some friends tell me it might end if I stop adding stuff then I would get it finished quicker - dead right I say!
Last Chapter we had the boot lid metalwork all finished. And the end result was quite good. All we had to do was prime, bog, sand and undercoat in readiness for the topcoat. Well all that has been done and the outcome was very satisfying. here is a pic of it sitting in front of the bonnet. Thats JC's 4EFTE powered Morris partly covered up sitting in the shot and 4 Paw sitting in the backgorund.
And speaking of doors......They were next. I wanted to do something slightly different with the doors, and something that was not too involved engineering wise - so I decided to utilise the door handles off the donor Honda Civic sitting in the back yard. These Civic door handles are really nice, and flush fitting, which is what I was after.
First things first was to remove the handles and the surrounding metal from the Civic doors. It is important to make sure that your cuts here are as square and straight as is possible, so as to make it easier when it comes to welding it into the Mini door.
Then transfer this to the Mini door, and mark the outline of where to make the cuts so it can drop straight in. Like I said before, the straight lines help. And this is what you should end up with - now on with the cutting using an air hacksaw and a lot of patience.
Once the cutting out is complete, and you have followed the lines with precision, this is what you should end up with.
And then we test fit the new panel piece in place and make any adjustments necessary to enable a good tight fit with only minimal gaps (like none!). Notice how nice and flush the Civic door handle is. Painted in the same colour as the car, it should look excellent!
Image.
If your wondering why all of a sudden the door is red, and then its bare metal, its because I ended up using a second door on the drivers side as the red one had some serious cancer reveal itself when we took the door pockets off - but thats another story! (note: lucky I had a spare, thanks Jeff!)
Then once its welded in, it should look something like this.
The secret here it to take your time. The way I did it, I spot welded a section, then hit it with an ice cube, then moved onto a different section, spot welded, cooled with ice cube - and so on until all the panel is completely welded in. It is extremely easy to distort a door panel by welding (just ask me, I did it on the other door). And once distorted, it takes some serious panel work to get things anywhere near right again!!!
After grinding off the weld with a flap disk, the end result should be something like this. Voila, nice and flush door handles to customise your Mini. Comes with integral lock mechanism too.
Okay, so another weekend of priming, bogging, sanding and undercoating until the door itself is finished. Here's how it turned out. Not bad if I do say so myself. (smooth as a baby's b#tt!)
With both doors done, and looking sweet, and with the boot totally finished, it was time to move onto the bonnet. Big plans!! I wanted to ultilise the 4EFTE Starlet bonnet scoop on the Mini bonnet, save bonding on an aftermarket one, which to me, never look anywhere near as good as the factory scoops.
So firstly, we cut the bonnet scoop out of the Starlet bonnet. I was blessed with my halfcut in that it came with a bonnet that was in pretty good nick. Here is the bonnet before being cut out - all we want is the intake part, with not much else.
So the cutout looked something like this. You can see that I followed the rounded profile of the front of the scoop and did not leave on too much metal - this is because I wanted to ensure that the front of the clubman bonnet, with the profile, remained intact. It would be much harder anyway to weld the new piece in following the curve at the front (no thanks!
Okay, so we follow the same procedure. Overlay the new piece onto the bonnet (as in the shot above), gauge where to cut minus a bit for trimming, cut it out. (side note: After a lot of measuring and aligning, I found out that the scoop could be located dead-centre on the mini bonnet because of the offset rubber apron underneath. This means it should seal the oil cooler just like the factory Starlet bonnet sealed the top mount intercooler). Then trim till the new piece fits like a finger in a bum, and then tack it in - simple!! After a weekend (yes another weekend!) on priming, sanding, bogging and undercoating, this is how the bonnet came out. A mate of mine commented that it is one of the toughest Mini bonnets he has ever seen, and I have to agree. Mind you, theres about 20 hours work in that bonnet. Here is some pics after bogging and sanding but before the undercoat.
I then decided I would get a little ahead of myself. After I had undercoated the bonnet and rubbed it down, I installed the little front scoop part and test fit the whole bonnet assembly onto the car to see how it would look. And in my opinion it looks bloody good!
Here is shot of the apprentice (Mitchell) holding up the front of the car. He's a great help (sometimes!)
And I just had to see how the scoop would blend in the the rest of the front - namely the Zeemax spoiler. To me, they both compliment each other extremely well and I can help but think of the word 'tough' when Iook at it.
Join us next time as we get the shell sandblasted and find out what a mistake that was. And then of course theres more bodywork to be done.........
PostPosted: Sun Mar 04, 2007 8:46 am
GOD DAM YOU ARE GOOD!
Baracade
PostPosted: Sun Mar 04, 2007 9:05 am
Reading about your work makes me want to larn to pannel beat and weld that much mor.
Great job and I love your idea's 8)
This space for rent
What he said. DAMN. This thing is incredible.
PostPosted: Sun Mar 04, 2007 9:19 am
Just something for you to think about archangle. When you used ice to cool the panel you are distorting it. You are much better to let it cool of with out the aid of ice. You see when you apply to much heat and dont wait for the welds to cool, the panel stretches and buckels yes. (distortion) When you let the panel cool off on its own it will shrink, this is why you see panel beaters (good ones atleas) planish the weld as it cools down (helps with shrinkage).
Now if you add ice to the weld you shrink the weld way to fast and it actually shrinks more then letting it cool by itself, and there is no chance of plannishing as it cools. And you will also get distortion it will just go the other way. When I weld things like rust patches in doors at work, I only stitch it in with welds about 5-7mm at a time, I let it cool right off so there is no heat in the panel at all before I weld on opposite side. When you get a few welds on the panel you can then weld one grind one weld one grind one. Be carefull when grinding to you get distortin from that aswell.
You might think it takes longer but you have none of this stuffing around after trying to get some shape back in the panel.
Hope this helps some people out.
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Mon Mar 05, 2007 12:21 pm
Thanks Mike,
Yes we could always use the advice of others if they are more skilled in that area.
Had more success though with the ice-cube technique than with any other.
But any advice you may give will be duly noted.
Thanks everyone else for their kind words - not long to go now!
Tricky
PostPosted: Mon Mar 05, 2007 1:44 pm
Before I even read your comments, as soon as I saw the pics I though
"That looks tough"
It really will be worth all the hard work & hours you have put into it.
Keep it up!
PostPosted: Tue Mar 06, 2007 8:19 pm
i never thought of usin the starlet bonnet scoop very clean :wink: its somthin for me to think about 8)
good work mate its comin along
PostPosted: Fri Mar 09, 2007 5:24 pm
Thanks awdmoke, thats the exact phrase that came to my mind as well - "that looks tough!!"
Glad to see we are of the same opinion.
SS - thanks for the kind words, should be complete in a few months time. Definately before the QB long weekend which is the QLD Mini Muster.
Tricky
PostPosted: Fri Mar 09, 2007 6:06 pm
Wow, you are awesome! Your car is awesome!
PostPosted: Fri Mar 09, 2007 6:50 pm
Thanks slinkey!
And thanks to sgc and gafmo too, its always nice to know your peers appreciate the time and effort that you have to put in.
We are now officially counting down.......... :wink:
Tricky
PostPosted: Sat Mar 10, 2007 12:08 pm
This space for rent
Archangel007 wrote:
Thanks slinkey!
Tricky
Hey, I'll be in Morayfield in a few weeks, feel like a visitor or three? Smegger (my brother) is frothing at the mouth over your conversion :lol: :lol:
PostPosted: Sat Mar 10, 2007 2:44 pm
sgc,
Absolutely, feel free to come around!
Its due to go to the spray painters in a coupple of weeks time to get the top-coat done, so let me know when and I will make do. :wink:
Tricky
PostPosted: Sat Mar 10, 2007 3:54 pm
This space for rent
Tricky
Ooohhh.. :drools: If the paint is anywhere near the quality of the rest of your work, I can't wait to see it :D
Looks like it'll be the week spanning Easter at this stage..
--s
