It is currently Mon Jul 07, 2025 5:00 pm
 Post subject: hypatec piston
PostPosted: Mon Feb 19, 2007 3:25 am
hello,
I will rebore my engine in 1275 +0.40 or +0.94
do you know if the hypatec piston are very reliable? are they able to run more than 80 000 miles in a stock engine?
you think about?
titi de lille
www.moroccominiraid.blogspot.com
 Post subject: Re: hypatec piston
PostPosted: Mon Feb 19, 2007 6:12 am
titi de lille wrote:
hello,
you think about?
titi de lille
Yes they are very reliable, the +.040" ones are of similar design to a Hepolite 21253, but stronger- as the oil drain slots are smaller.
The 73.0mm ones (+.094") are similar design but even stronger as they use oil drain holes, not slots.
Many people use them for racing, they are a strong piston.
My rebuilt 1360 has them, it has now done about 5000 miles and is using NO oil. 8)
PostPosted: Mon Feb 19, 2007 6:22 am
hi,
thanks a lot for your information.
do you think they are reliable for more than 80 000 miles? because I use my mini not often , but when I use it, I run about 12h at 3800 rpm to cross france ( 630 miles ) or for imm and now for my event ( morocco mini raid in north of africa.
regards
PostPosted: Mon Feb 19, 2007 6:24 am
I believe you will not find a better piston for life, they have a high silicon content and will last much better than forged ones for road use. :wink:
PostPosted: Mon Feb 19, 2007 6:27 am
you are fast to answer :D
for it's better than omega or powermax?
have a look on my web site , you see , why I search very realiable piston and engine
PostPosted: Mon Feb 19, 2007 6:56 am
Better than Powermax, definitely. :wink:
The Omegas, I have not used.
PostPosted: Mon Feb 19, 2007 7:06 am
thanks a lot
PostPosted: Wed Feb 21, 2007 7:42 pm
The hyptec got my money.
Also used here in NZ,
Good value for money
Kiwiinwgtn
PostPosted: Wed Feb 21, 2007 8:25 pm
I have another set of 73mm Hypatecs (with Russell Engineering modified dish) going into the 1412 stroker. 8)
Fot the wife's Clubby van.... :wink:
PostPosted: Thu Feb 22, 2007 5:48 pm
to have a1412; you chnage your cranckshaft?
PostPosted: Thu Feb 22, 2007 6:36 pm
I'm using an early 12G1505 large journal (still std/std size) 1275 crank, the rod journals have been offset ground to 1.625". It's now 84.33mm stroke.
Also I've wedged it, and had it balanced.
Conrods are Cooper S. 8)
PostPosted: Fri Feb 23, 2007 12:04 am
I have a friend who try piston a car but I know which and is engine if it's work will be 1440cc.
Users browsing this forum: No registered users and 23 guests
