It is currently Tue Jun 24, 2025 8:00 pm
 Post subject: boosting dual circuit
PostPosted: Wed Nov 24, 2004 9:22 am
hey guys is it possible to boost a dual circuit brake set up ? is just the front or rear circuit boosted ? thanks.
lookin for another clubby
PostPosted: Wed Nov 24, 2004 10:38 am
yes, but genrally it is just the fronts that are boosted.
Aaron
PostPosted: Wed Nov 24, 2004 12:00 pm
Aaron
ok sweet :D next question . how ?
PostPosted: Wed Nov 24, 2004 12:17 pm
Anyone with a ls 2175 or GT has it set up. Hard explain but easy to show.
aaron
PostPosted: Wed Nov 24, 2004 4:27 pm
PM me and I'll explain. :lol:
PostPosted: Wed Nov 24, 2004 4:30 pm
i have a dual circut setup with a booster.
From the master the front line goes to the booster inlet (mines under the dash) then from the booster outlet it goes to a T intersection and then to both front calipers.
The rear line goes through a brake light switch then to the T intersection at the rear of the car.
1974 Moke - 998cc
PostPosted: Thu Nov 25, 2004 7:56 am
re: late model clubby dual circuit system - is it any good? Is it worth swapping into an older clubby without this set up?
PostPosted: Thu Nov 25, 2004 8:24 am
dont know if its worth it but im doing it because i got all the gear free :D thanks for clearing everything up guys :D
PostPosted: Thu Nov 25, 2004 11:27 am
They are better, but a little more of a pain to bleed. Not really a big issue though.
aaron
PostPosted: Thu Nov 25, 2004 11:32 am
why are they better?
PostPosted: Thu Nov 25, 2004 11:42 am
i think if one 'circuit' fails the valve blocks it off and directs all power to the remaining active circuit?
PostPosted: Thu Nov 25, 2004 11:59 am
hence the brake fail light on the dash?
PostPosted: Thu Nov 25, 2004 12:14 pm
i think so ?:D but im not fitting those lights, because im sure i would know if the brakes failed. im going to cover the ashtray hole and the 2 light holes, then trim the rail im yellow vinyl.
PostPosted: Thu Nov 25, 2004 2:31 pm
The brake fail light is connected to a switch which is activated when there is a difference in pressure between the two lines. The valve and switch are in that H shaped thing in the engine bay
PostPosted: Thu Nov 25, 2004 7:10 pm
Ask Brad (13secmini)- it didn't work for him, before or after the MC was rebuilt by Better Brakes.
He found if he blocked the rear line, he had pedal! Problem was air leaks into rear wheel cyls. So much for dual circuits!
Now, how is this dual circuit thing supposed to work in an emergency, again.. :lol: :evil:
