It is currently Thu Jun 26, 2025 10:14 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Feb 11, 2007 2:57 pm
If your battery terminal is getting hot, then it is sucking some large amount of juice. I'm guessing although that the battery terminal is tight.
You need to find if you've got a fundamental problem with your starter motor /solenoid somewhere. To prove this you need to measure the voltage at the starter motor as you turn the key to start. If it drops away by a large amount without any turning over, then the starter motor is bung or jammed or something.
Go back to what you previously had and try again.
PostPosted: Sun Feb 11, 2007 5:04 pm
got it running today
Thanks to David (64cooper) he spotted the loose -ve wire after removing the battery
Battery is currently low voltage after cranking it
found the most silliest thing as well... when I replace the starter motor, I removed the coil and somehow the HT lead is not put in properly thats why its just cranking :oops: :oops:
I was more concenrating on battery, fuel pump and starter motor and ignored the basics to check
PostPosted: Sun Feb 11, 2007 5:07 pm
Good to hear it's running , as for the loose -ve wire , don't worry , we've all done similar at some stage and gone chasing what we thought was wrong and missed the obvious thing ...
David, fuel pump seems working fine, I'll return your fuel pump early this week maybe tomorrow, I'll give you a call 1st though
Thanks again!
PostPosted: Sun Feb 11, 2007 5:11 pm
I've got 2 free wire slots on my -ve terminal should I put extra earthing points?
Users browsing this forum: No registered users and 112 guests
