It is currently Sat Jul 05, 2025 4:34 pm
 Post subject: VTEC conversion
PostPosted: Fri Feb 09, 2007 8:09 pm
Hi,
There is a place in US which sells the preassmbled Honda Engine Package for $US10,145 = $AUS13,019.7683:
http://www.superfastminis.com/honda_engine_package.htm
Is it worthwhile to get it here and let Mr Enforcer to put it on. Will there be any good saings from doing this rather than asking Enforcer to do the whole thing?
Also if I get this package, how many % of the mechanical/wiring work has been done and what would be the remaining to do? I mean what are the other technical things left to do?
Thanks
Ben
1964 Morris Mini 850 - G13b gti powered - classic yet practical
1968 Morris Minimatic - 1100cc - classic & breakable
Sun Certified Java Programmer v5 310-055
PostPosted: Fri Feb 09, 2007 8:42 pm
well... given that Mr Enforcer offers a 4EFTE drive in-drive out for around the AUD$10K mark, I'd say it'll cost you substantially more to import this gear from USA..... and expect $1K+ in freight to bring it in, and pay GST on the import, and you'll have to get the sheet metal work done if it needs the front extended, and wiring it up to a dash, setting up an exhaust, and and and....
I'd assume Mr Enforcer would charge you a couple of grand at least to install it - but you'd have to ask them
ask that mob how much else needs to be done to install their kit in a mini and have it driving, I bet it's a lot...
not worth it IMHO
PostPosted: Fri Feb 09, 2007 8:52 pm
Hi,
I assume the starlet engine + box is not included in the around-$10K -package.
I rang him yesterday, waiting for his e-mail.
Ben
PostPosted: Fri Feb 09, 2007 8:53 pm
I bet that Honda package is for a LHD Mini.
Be careful fitting Hondas to a RHD Mini, in many cases they say the diff housing fouls the rack- meaning either the rack and toeboard needs to move back 40mm into the car, or the front guards need to be made longer.
Hate to see you spend A$13 large on bits and find it won't fit.:(
PostPosted: Fri Feb 09, 2007 9:22 pm
My shell is a clubman.
PostPosted: Sat Feb 10, 2007 5:24 am
Also, you might want to watch the track, apparently a couple of guys in VIC have had trouble with their VTEC kit because the track had increased too much.
 Post subject: VTEC concersion
PostPosted: Sat Feb 10, 2007 11:16 pm
There is a company in the UK who make kits for VTEC conversions. As they drive on the same side of the road as us, you could assume that clearances would be taken care of.
PostPosted: Sun Feb 11, 2007 5:26 pm
track might not meet requirments
:wink:
PostPosted: Sun Feb 11, 2007 5:55 pm
... and the UK kit (Watson's) needs the body lengthened at the front, at least all the info I've read and pics I've seen say so.
And it's not just a case of using a Clubby body instead, the room in there low down where the subframe sits is the same as in a roundy.
Same subframe. :wink:
PostPosted: Sun Feb 11, 2007 8:06 pm
Or....alittle closer to home for ya try here in NZ
http://www.mendozamechanical.co.nz/index.asp?pgid=54
Sean has worked pretty hard to get this off the ground.....
If you idiot proof the world, only idiots there shall be!!!!!
PostPosted: Mon Feb 19, 2007 1:27 pm
I've had a look at that website before and they do state that the kit is for both LHD and RHD. Also should note that the kit includes the engine mounted with full front suspension and brakes. So it should only be a case of bolting it straight on (aye, that easy haha).
They do also say that the nose needs to be lengthened by about 4 inches, or buy one of their pop up body kits. Nothing about the tracking issue though.
