It is currently Thu Jun 26, 2025 5:47 am
Post new topic Reply to topic  [ 77 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Jan 30, 2007 9:46 pm
Hey guys i finally got up and bought the half cut! its now time to put .....
this:
into this:
As you can see the mini is in a sorry state and ive got a lot of work ahead of me. Lots of plans in store for GOF :P :wink:
Before i start i have to say heaps of thanks to minstar for his website being so helpful and motivating me! and archangel007 for helping me out with the engineer report :D
Ok, i got the half-cut delivered to mine yesterday but to my surprise it arrived on the back of a ute! so i had to use my engine crane and roof winch to get it of and after much effort finally got it onto a pallet!
Today after a long rest and night of planning i started with the dash and started to remove the ecu and wiring loom, since i wasnt planning to keep the dash itself (just the gauges so i could sell them) i cut up a bit of it in order to reach some of the wiring, being careful not to cut wires in the process :P
i also started to remove the intercooler radiator and some piping in the engine bay
Does anybody know how to remove this metal bracket above the pedals? ive undo the two bottom bolts and i cant seem to find anymore but it just wont budge! i have to get it out of the road to remove the gauges and reach the speedo cable
PostPosted: Tue Jan 30, 2007 9:52 pm
lol ... dont u kno how to undo scres and bolts? :P
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Tue Jan 30, 2007 9:55 pm
haha that was when i was starting to get frustrated and got into it the the angle grinder only to realsi it wold work much better if i undid all the screws instead of butchering it:P. managed to fix most of it up now though hehe
PostPosted: Wed Jan 31, 2007 1:27 pm
If i remember correctly that bracket was fixed to that big pipe running from one side of the car to the other.
Make sure you start labeling all the wires with duct tape and a black texta. Dont use masking tape because it will fall of and the texta will fade.
My 2c worth
By the way welcome to the land of Starlet Minis and strap yourself in for an interesting ride.
Dan
PostPosted: Wed Jan 31, 2007 2:23 pm
My 2c worth
Dan
thanks dan :D i started labeling the wires with electriacal kind of tape but im finding it hard to write on with the texta so ive switched over to the duct tape. Theres so many wires in the engine bay! lots of respect to all you guys that have already done this it is way harder than it looks. im trying not to stuff up the fuel management system atm and its going well still :)
should have another update tonight
PostPosted: Wed Jan 31, 2007 5:29 pm
Good Luck GOF, yeah it is difficult to finish but once done it more than worth it. If you need any advice just PM me.
Matt
PostPosted: Wed Jan 31, 2007 6:08 pm
Wanting to do a starlet conversion down the line, its always good to see how other people are going about it. Good to see all the photos and progress report.
Good Luck
PostPosted: Wed Jan 31, 2007 7:03 pm
Goffy,
Where are you located?
Make sure you keep all parts that you feel may be of use even down to cables and brackets.
Goes for me to, if you need any help or info then just post or PM.
Dan
PostPosted: Wed Jan 31, 2007 11:41 pm
thanks for the kind words guys :), oh im up in good old brisbane seeing if i can be starlet mini number 2 after archangel's hehe
I never got around to downloading the pictures of what i did for the rest of the day so ill do it first thing in the morning, but i did manage to invest in a welder so tomorrow morning im refreshing my welding skills..its been a while :P lol.
Goffy
PostPosted: Thu Feb 01, 2007 8:11 am
minimetoy wrote:
Goffy,
Dan
Goffy,
Since you are in Brisbane, let me offer my services.......
If you need advice or whatever, feel free to ask.
There is a plethora of talented Starlet converters on here that have a fountain of collective knowledge. Use it to your advantage.
Good luck,
Tricky
Burpengary, Brisbane.
PostPosted: Fri Feb 02, 2007 6:16 pm
Thanks tricky, im starting to lean towards asking you about making the subframe depending on what my engineer thinks :D. also this has got to be the friendliest forum ive ever been on the help here is one of a kind :).
Update today.... i have finally removed everything other than the drive shafts and the gear change from the gearbox. i took the turbo off straight from the manifold cause the exhaust bolts were all rusted so there was no way i could undo the exhaust and remove it so i just took the lot out in one go.
Ive invested in some car stands to put the half cut on making it so much easier to work on too.
im having trouble removing the drive shafts and the gear change from the gearbox side of the halfcut. with the drive shafts issue ive undone the engien mounts and lowered the engine on the crane as low as it can go and have been trying to undo them with no luck. Also with the gear change i cant seem to undo it from teh gearbox.
Sorry aboutno photos im at work but tomorrow morning ill update wil all photos of what ive done so far
cheers, Goffy
PostPosted: Sat Feb 03, 2007 9:35 pm
Goffy
What side of the shafts are you trying to remove??
To remove the inside side just undo the clips on the rubber boots and they will slip out but that will depend on if your strut is out, brakes dismantled etc. I actual wedged a huge screwdriver between the studs and the garage floor then put my socket on the castel nut and jumped up and down on my socket bar, after a bit of effort i finally cracked it. You remove the nut and pull the whole strut away whilst lightly taping the shaft out of its position.
The gear change should have 4 bolts at the plastic base which you remove and thats it. Most of us then cut (drilled out the spot welds) the mount out.
With the shafts you could just get the angle grinder out and cut the shaft off right at the CV. You will find that the shaft will still be long enough to be cut down to the right size.
Hope this helps.
Dan
PostPosted: Mon Feb 05, 2007 7:37 am
Goffy,
Where abouts in Brisvegas are you located?
I would be able to do a subframe for you, no worries there.
Like Dan said, undo all the suspension, disassemble everything, then take the driveshafts out. It makes the whole job easier.
Disconnect the gear change cables from off the gearbox side, (label them first), and then disconnect the shifter mechanism as per Dan's instructions (4 bolts into trans. tunnel), then take the shifter mechanism and cables out as one unit.
PM or post if you need any help!
Tricky
PostPosted: Mon Feb 05, 2007 9:05 am
Its tough living in the shadows....... :roll:
PostPosted: Mon Feb 05, 2007 10:07 am
C'mon JC we need to see some photos of the beast, so we don't forget about you :lol: :lol:
Pretty please with a cherry on top.
Dan
Users browsing this forum: No registered users and 27 guests
