It is currently Mon Jul 07, 2025 12:35 pm
 Post subject: ??sc12 dump valve??
PostPosted: Fri Jan 26, 2007 5:07 am
Alright guys,
With the SC12 supercharger kit, does a dump valve need to be fitted off the backfire valve?
i guess the backfire valve is to release the pressure out of the inlet manifold.
PostPosted: Fri Jan 26, 2007 3:48 pm
this has been discussed before, cant find it?
PostPosted: Fri Jan 26, 2007 4:10 pm
The backfire valve vents to atmosphere only in the event of backfire to release the pressure in the manifold as not to damage the SC.
You can't use a blow off valve because as soon as the throttle is shut there is no boost build up as it is a suck through system.
4efte powered Clubman
supercharged 998 race car
PostPosted: Fri Jan 26, 2007 5:43 pm
ah i see, makes more sence now.
Cheers for the help :D
just got to get all the bits for my engine now and build it, cant waite. charger is on its way!
