It is currently Mon Jul 07, 2025 12:55 pm
PostPosted: Sun Jan 14, 2007 9:27 pm
The Forkmeister
I finally got around to upgrading my cooling system this week-end, new highflow water pump (1275 pump), new thermostat and a super cool two core radiator form Karcraft. I must admit I have been putting it off a bit after hearing some of the horror stories about changing radiators in these cars.
The effort appears to be worth it though after taking it for a good drive in some decent temps the car ran nice and cool..... :D , I took some pictures of the work and once I figure out how to post them I'll put them up.
Cheers Gerg
May the fork be with you.
PostPosted: Sun Jan 14, 2007 9:30 pm
I put the same 2 core thing in my car last week, from Karcraft. The difference is HUGE. I've gone from running 15 degrees too hot to running 15 degrees too cool, which may not be a good thing for the oil..but for a road car it shouldn'e be too bad. The volume difference between the UK 3 core and the 2 core is unbelievable, the 2 core takes about twice the coolant! :D Definitely worth the money.
PostPosted: Sun Jan 14, 2007 9:31 pm
Good stuff buddy. Sounds coooool
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Sun Jan 14, 2007 10:15 pm
The Forkmeister
Thanks guys, I was just wondering what are these engines normal running temps suspose to be ?, I have a 998 with twin 1/14 su's and sports exhaust, (the rest is a bit of a mistry ).
Gerg
PostPosted: Tue Jan 16, 2007 5:53 pm
Does the 2 core radiator that you got (for Clubbie) have the top metal tube attached for the heater outlet? Thanks.
PostPosted: Tue Jan 16, 2007 7:58 pm
The Forkmeister
No, it does not have the top tube for the heater, I didn't know you could get one with this ?. My car is a 1972 model, was that for a later model or older?.
Cheers Gerg
PostPosted: Tue Jan 16, 2007 8:38 pm
I'm pretty sure that pipe was an Oz Clubby thing only.
If no pipe on rad, just use a bottom hose with a heater connection. :wink:
PostPosted: Tue Jan 16, 2007 9:18 pm
Okay-Thanks.
PostPosted: Wed Jan 17, 2007 7:43 pm
The Forkmeister
I knew that......... :D , mine actually uses the bottom rad hose that the good Doc is talking about.
Gerg
PostPosted: Fri Jan 19, 2007 11:32 pm
has anyone taken the engine fan off and just run a good electric fan.. they say it will free up about 1hp because ya don't have the drag of the fan
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
PostPosted: Sat Jan 20, 2007 11:49 am
The Forkmeister
Hi Mrclubby,
That can be done for sure, but I don't think thats a popular mod on mini's, I don't know if it's a space problem or not, but I have seen a lot who acually put on the 6 blade fans or even the 2 blade fans that preform well and reduce drag on the engine. I'm assuming you have the plastic 11 blade fan that I have on mine..
Gerg.
PostPosted: Sat Jan 20, 2007 10:51 pm
I got both mech fan and thermo fan.
Thermo fan is from a Jap Rover and is built in a rectangle cowling box thing that covers the hole in the wheel well to let air out of the radiator. It's quite cool actaully. I have it on a automatic switch (from the Jap Rover as well) that turns the fan on when the needle on the guage gies jsut above 'N', this helps in hot traffic.
 Post subject: fans
PostPosted: Fri Jan 26, 2007 1:22 pm
any chance of some pics of that slinky? we need to do something similair with our UK Austin 1300 - runs very hot no matter what we've tried so far.
K
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Fri Jan 26, 2007 9:49 pm
If I get the time 2moro I'll jack up that side of the car and take a pic. I'm pretty busy 2moro with other mini work (as I always am...) but will make a minute or two to do that for ya.
PostPosted: Fri Jan 26, 2007 10:06 pm
thanks slinkey - just if you get the time 8)
'71 Wolseley 1300
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
