It is currently Sun Jul 06, 2025 3:31 am
Post new topic Reply to topic  [ 107 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
PostPosted: Mon Jan 08, 2007 9:20 pm
Then buy Des Hammil's book, powertuning 1275's he has "some" building tips in there, some of it is rubbish...
Why? gosh that part will cost you money! :wink:
Lillee wrote:
1) Use LMM grease under the head and on the threads of rod bolts and mains bolts before torquing them up
This is so that you can torque them up properly. If there is no grease on the threads or the heads will grab and you will get innacurate torque readings
2) Don't skimp, Redistrip you block, it's worth it
My block was good inside but the paint outside was really bad. Although I did a darn good job, at the end of the day it would have been easier to redistrip it for $100
3) Keep things as clean as possible. When it's spotless, clean it again. Keep things "unexposed" to dust and moisture.
Doesn't take much metal filings or gunk to ruin a motor first time you turn it over
4) Use a good engine lube when you rebuild, put some on all bearing surfaces, cam followers, cam lobes, etc.
This is to lubricate the bearing surfaces to aid bedding in and prevent dammage when turning the engine over
5) LMM between valve and tappets
same as above
6) LMM on all seals at assembly stage
same as above, doesn't take much to destroy a ruber seal when putting it on and turning the engine over dry
7) When dry assembling, be careful not to dammage the bearing surfaces, try using tape to tape up bearing cap locators etc. Use plenty of assembly lube
Unless you want to regrind the crank and buy new bearings before you've even used them
tired of typing now...
1. If you don't know the history of the engine, many of which are 40+ years old now- and particularly if you are building it to have a rev, toss all the rod bolts away and buy new ones. Preferably ARPs for a bigbore, but you can use Unbrako socket head cap screws for smallbores.
Number 1 total engine killer (and I mean TOTAL) is rod bolts letting go
2. Get the rods checked for straightness. You will be lucky if they are straight...
Aaron and I measured 16 factory 998 rods and all but 4 were bent, some up to 100 thou or more! The 4 that were straight were still bent by 3-6 thou :shock:
639) Use good oil, change it often. Don't skimp on $20 of oil once you've built your $5000 dream machine. KMX (Kmart's own brand) is $13 for 6L. It's good stuff, better to use that and change every 1000miles than every 6000miles like the book says. Drmini changed every 1500 miles, that's a good interval
640) Change the filter just as often. $4 for FSA brand Z418 filters at Canley Vale Road Canley Vale. What more can I say?
641) Drill out the oil feed on the spin on oil filter mount. More oil, more lube, more engine life.
642) Buy a pirtek hose and connections to replace the metal oil feed to the filter. More oil, more lube, more engine life. If you use the metal ones, use the direct feed J bend pipe and not the bango type pipe as the J pipe flows abit better.
643) Cush should read more and not be so lazy
 Post subject: balancing
PostPosted: Mon Jan 08, 2007 11:49 pm
would you need to get the crank,clutch,flywheel,clutch all balanced(dynamic) once its assembled?. Or would individually suffice?. I have heard that dynamic balancing is very expensive.
blokeinamoke wrote:
 Post subject: 998 or 1098
PostPosted: Mon Jan 08, 2007 11:53 pm
If I was building something I was going to flog would it be better using the shorter crank?
Or do 1100 and 1000 rev pretty much the same anyway? If they did the xtra 100cc would help.
blokeinamoke wrote:
 Post subject: lastly
PostPosted: Mon Jan 08, 2007 11:57 pm
I have a really good block here that probly just needs a hone. And I have another one that needs a rebore.
For a tough engine would I be better off keeping the bore close to standard and have thicker walls, or bore the crap out of it to get a few more cc's. I dont really think It would be worth it.
Opinions?
blokeinamoke wrote:
 Post subject: Re: 998 or 1098
PostPosted: Tue Jan 09, 2007 5:52 am
For a road car I'd go the 1098 crank, that extra 100cc really helps torque and makes for a more drivable car.
Yes, you can bore a 998 out by .100" now, but very soon, Russell Engineering will have .100" oversize pistons for a 1098 too. That's around 1184cc... no substitute for cubic inches!! :P
A well prepared motor with 1098 crank is good for 7000 rpm, heaps on a road car.
 Post subject: Re: balancing
PostPosted: Tue Jan 09, 2007 7:50 am
You don't "need" to have it done but it is better to check the balancing. Yes the crank., flywheel and backplate are balanced individually then assembled and balanced together. As far as I know there is no other way to balance these items except to dynamically balance it. What else is there? weights and scales?? :?
Russell Engineering can do it properly for you for around $150? (don't quote me on that cuase I got more than 1 thing done at a time) call him for a definate price.
PostPosted: Tue Jan 09, 2007 8:32 am
for the Block
When I build me next 9998/1098 I will Be crack testing a 1098 crank and making sure all ends are perfect...Balanced and the balanced with the slighlet lightened flywheel and back plate and balanced again together. The get the rods slightley lightened and balnced also
Block will be bored to the next size up only with new piston and rings once the block has been diped and full cleaned up and getting my favorite engine builder to put that together correctly for me.
Cam of my choice and a Double row timeing Chain, New Followers and oil pump
Myself to Piaint it Paint..End of Story
PostPosted: Tue Jan 09, 2007 9:19 am
I had the crank, crack tested, ground 20 thou under, balanced and the rods straightened for $380.(The rods doubled the original quote) The harmonic balancer was $150 to be re- vulcanized and balanced ( they broke the original cast pulley and turned up a new one in steel - all for the original quote) and I am now going to have the flywheel faced and balanced then all three balanced together. No quote yet but has to be done. Now I have new ARP bolts in the rods they will have to be recentred
David L
 Post subject: 100" oversize pistons
PostPosted: Tue Jan 09, 2007 11:26 am
100" oversize pistons sshhwwiinnggg!!!!!!!!! :D the cost of these would not be up around extortion would they?
Cheers doc
blokeinamoke wrote:
PostPosted: Tue Jan 09, 2007 11:57 am
I know how to make the A-series motor bullet proof.
Build it ... then don't drive it ! :D
PostPosted: Tue Jan 09, 2007 12:33 pm
Cheers doc
No, they should be under $300/set, with rings. :wink:
PostPosted: Tue Jan 09, 2007 12:35 pm
Build it ... then don't drive it the way i drive it ! :D
PostPosted: Tue Jan 09, 2007 12:49 pm
:lol: :lol: :wink:
PostPosted: Tue Jan 09, 2007 1:52 pm
To this date I have had no mechanical failures, even with my first Leyland which i owned for almost three years
PostPosted: Tue Jan 09, 2007 3:25 pm
Do engine and exhaust mounts count?
Users browsing this forum: No registered users and 23 guests
