It is currently Mon Jul 07, 2025 9:22 am
PostPosted: Fri Dec 29, 2006 2:53 pm
Hey all Got a new set of twins for xmas thought you might like a look. They are inch 3/4. Was wondering if there was anyone out there that was running them??? Im intrested in what size engine they were attached to?? I am thinking on putting them on 1275 with a worked head and cam. Any comments would be great. Happy New Year to you all
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
NZ 79 1275gt clubman estate
79 LE
80 meanee
Racecar
Fiat 500
PostPosted: Fri Dec 29, 2006 3:14 pm
Give Ash some flowers Nick .
I could tell you if you posted up the numbers on the top of the float bowl on the little piece of metal. These would go great on a HOT 1275 as USUALLY most mini's (even 1275's) use 1.5" twins as the biggest carb - it depends on the spec level of your engine.
PostPosted: Fri Dec 29, 2006 3:15 pm
They'd work marvelously on a worked 1275 but it'd want to have a fair bit of work done to it to truly get the potential out of them. Other than that what bloody nice twin very yummy indeed!!!
PostPosted: Fri Dec 29, 2006 3:18 pm
Should of said before, a set of twin HS2's (1.25") can handle upto about 75 - 80hp from an engine before they need to go bigger - so yeah, what 1360 LS said, it would need a really racey engine.
PostPosted: Fri Dec 29, 2006 3:25 pm
It'd want to have at least 110 but I'd even go as far to say minimum spec engine would be chong's 1330 and that 119 from memory. You want to attach it to a race engine preferably.
PostPosted: Fri Dec 29, 2006 3:36 pm
Nothing looks better on a classic mini than twins 8) I think twins look the business on a nicely restored mini
PostPosted: Fri Dec 29, 2006 3:37 pm
Yeah they are most likely too big for any 1275 aplication I've seen on the roads. They look tough though, do a graham russel and work them a bit (check Mini experience, second to newest issue I think.) and get them sorted and they would truly be a full race setup.
PostPosted: Fri Dec 29, 2006 3:55 pm
they will be fine on your 1330 :D seeking more power are ya? :P
PostPosted: Fri Dec 29, 2006 4:29 pm
Could be off a number of British cars, Jaguar S-Type/420/Mk2 2.4, Dolomite Sprint, Triumph 2500, Rover 3 litre, Austin A90 etc etc.
PostPosted: Fri Dec 29, 2006 4:35 pm
I ran twin 1.75 inch SUs on my 1330 with no problems at all. Yes it was a daily driver too
PostPosted: Fri Dec 29, 2006 4:37 pm
No sir, the Dellorto sounds FAR too sexy to go for twins! :wink:
PostPosted: Fri Dec 29, 2006 5:25 pm
heheheh, with 119.7bhp why would you change :D
brik_nuts also has a 1330 :)
PostPosted: Fri Dec 29, 2006 6:15 pm
Oh I see :wink: "Big is not always better" :wink:
PostPosted: Fri Dec 29, 2006 6:22 pm
easy for you to say mister 119.7 :lol:
PostPosted: Sat Dec 30, 2006 4:08 pm
Hey thanks for that. New delemer do I put them on my 1330 and take the 40 weber off? Im puting a new head n cam into it in the new year to give it more power.I dont wana bore out am engine just put the large twins on.So I mite buy a set of 1 1/2 twins off my mate for the 1275 engine.
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
79 LE
80 meanee
Racecar
Fiat 500
