It is currently Tue Jul 01, 2025 10:09 pm
Post new topic Reply to topic  [ 1054 posts ]  Go to page Previous  1 ... 37, 38, 39, 40, 41, 42, 43 ... 71  Next
PostPosted: Wed Dec 27, 2006 2:09 pm
I believe it required some hand rubbing with 2000grit sandpaper to get rid of the roughness, then it was buffed with the dremel..
PostPosted: Wed Dec 27, 2006 4:41 pm
I had to use a sanding bit on the dremel to get it flat as it has dimples all over it. Then i dry sanded it with 120 grit by hand, then 800 grit wet and dry, then 1200 grit wet. Then back with the dremel with polishing bit and metal polish.
1974 Moke - 998cc
PostPosted: Wed Dec 27, 2006 4:44 pm
see..i told you he did it :lol:
Thanks :D
PostPosted: Fri Dec 29, 2006 3:04 pm
Is there anything I actually did on pj?
hmmmmm
PostPosted: Fri Dec 29, 2006 3:07 pm
whinja ninja
whinja ninja
josh, you seem to be more of a delegator...and everythig has worked fine on your car so far. Dont psh your luck and actually do some work on it. You'll probably break it.
I don't know my name anymore.
PostPosted: Fri Dec 29, 2006 3:24 pm
That's great advice adeee, it's gonna be hard, but I'll take it :wink:
PostPosted: Fri Dec 29, 2006 3:27 pm
whinja ninja
whinja ninja
and i can quite comfortably give that advice because i know i will never be one of the people doing work on your car.
PostPosted: Fri Dec 29, 2006 3:46 pm
is that because you are hopeless ?
PostPosted: Fri Dec 29, 2006 3:53 pm
whinja ninja
whinja ninja
possibly...but more to the fact that it'll take you 18 hours to get the car down here.
PostPosted: Fri Dec 29, 2006 6:55 pm
Josh.....Nice Bling I can't wait to See It 8)
Brad...I know the effort it would takes to bling a surface or two and that's a great job 8)
Emm....I knew you had to have a hand in it also :wink:
PostPosted: Fri Jan 05, 2007 11:12 am
dropped past brads place and saw him working on it, so i stopped for a geez
coming along nicely, dash is going to look hectic!
well done josh you are going to have a sick arse car :)
ausmini member #10
(22:42:45) 5 years later..........
PostPosted: Fri Jan 05, 2007 2:22 pm
Thanks dude, not sure how well i'll pull off the dash though :lol: :?
Good news is the auto leccy is creating a new front loom on the 13/14th Jan, then on the 16 or 17th it goes in to get the computer done and it shouldn't be too long after that! :)
Huge thanks to Aaron for letting my try my wheels out on his van which has W&P arches, so i'm going to buy a set now..here's some pics:
PostPosted: Fri Jan 05, 2007 2:25 pm
Also got myself a new SARD Fuel Regulator..here is one of the locals from cabramatta modelling it...
Then Em showed him a thing or two...
PostPosted: Fri Jan 05, 2007 5:44 pm
ah jish - did ya getta whole shot of the van with your wheels?
its looked nice from what i can see :lol:
is that acceptable clearance for the arches?
a girlfriend would be cheaper
Yeah arches look sweet...
dam... polishing... whats that?
Baracade
