It is currently Sat Jul 05, 2025 10:12 pm
PostPosted: Tue Dec 26, 2006 7:10 pm
resident alien
resident alien
So you put them inside this?
PostPosted: Tue Dec 26, 2006 7:24 pm
Yep. 8)
same screws.
They really tidy up the low speed running, even with my RE282 cam. I won't run a Dellorto without them now. :wink:
Last edited by drmini in aust on Tue Dec 26, 2006 7:26 pm, edited 1 time in total.
PostPosted: Tue Dec 26, 2006 7:25 pm
Yes.
KB
PostPosted: Tue Dec 26, 2006 7:52 pm
No i have them inside a 2" K&N at the end of a GR 5 1/4" intake 8)
PostPosted: Tue Dec 26, 2006 8:25 pm
See, they'll work anywhere.. even in a K&N. :lol:
PostPosted: Tue Dec 26, 2006 8:38 pm
resident alien
resident alien
So what benefit would there be if I put them inside what I have?
PostPosted: Tue Dec 26, 2006 8:50 pm
Read Vizard, air travels faster into a hole with rounded off egdes than a hole with sharp 90* edges. In theory air will travel faster into your carb, more air, more fuel, more power!
PostPosted: Tue Dec 26, 2006 8:53 pm
resident alien
resident alien
So Dr. Mini... do you have any for a 40 DCOE Weber?
PostPosted: Tue Dec 26, 2006 9:37 pm
I wanna run tubes and socks...
Will stub stacks help?
PostPosted: Tue Dec 26, 2006 9:47 pm
Marvin, I have none left but will make some more- soon.
They will fit either Weber or Dellorto, no difference in mounting.
willy, they replace ramtubes, if you have a short filter and no room. Won't work with socks.
If you want short ones to run with socks speak to GR he pressforms real short ramtubes with a rolled end.
PostPosted: Tue Dec 26, 2006 10:03 pm
I see...
Yeah I ****ing love the look of tubes and socks so this is what i'll be running :P
Race car styles :twisted:
PostPosted: Wed Dec 27, 2006 5:45 am
A little OT but related-
For SUs, stubstacks are also available from K&N, and Keith Calver in UK. He makes his because he reckons the K&N ones don't work. See http://www.calverst.com/
Graham Russell machines a radius into the mouth of his SUs, that works too. But you need to then open up the filter hole.
PostPosted: Wed Dec 27, 2006 6:45 am
DOZ wrote:
See the pics of Chongs box
http://www.ausmini.com/forums/viewtopic ... &start=289
for an idea. I have welded these out of MS before but don't have the facilities atm. I made one for a panel van that has magnolia vdo gauges in the cabin and can fit a conventional K&N filter.
Daniel
hehe Chong's Box hehe couldn't resist
