It is currently Sun Jun 22, 2025 5:12 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Nov 05, 2006 7:12 pm
Baker wrote:
Just because the manufacturer has not specified a towing weight does not mean it is illegal to tow with it. The RTA (NSW) rules specify what rules apply to cars without a towing weight.
If the vehicle manufacturer has not specified the maximum towing mass, the maximum towing mass is:
One and a half times the unladen mass of the towing vehicle, provided that the trailer is fitted with brakes which are connected and in working order, or
The unladen mass of the towing vehicle if the trailer
does not require brakes
So looking at that you may be better off with a Cooper S :twisted:
OK, so then as its a chassis modification you'd really need to get it engineered then to be legal. Really don't think you'll find someone who'll engineer it!
I don't think it would need engineering. Probably should take a look at... http://www.vicroads.vic.gov.au/vrpdf/rdsafe/VSI%2024.pdf
PostPosted: Sun Nov 05, 2006 7:52 pm
I dont want to enginner anything, I just wanted to know if anyone knew the towing capacity of a MINI :roll:
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Tue Nov 07, 2006 11:23 am
I've looked into getting a towbar, they don't make one for the cooper s only a cooper.
PostPosted: Tue Nov 07, 2006 11:46 am
Thanks, I kinda worked that out from the dealers
