It is currently Sun Jul 27, 2025 6:38 am
PostPosted: Thu Oct 26, 2006 9:52 pm
For twin HS2's on a 1275, should I use red or blue springs?
PostPosted: Thu Oct 26, 2006 9:56 pm
Depends on if your running standard air box or sports filters - in which case I'd vote red.
PostPosted: Thu Oct 26, 2006 9:58 pm
Pretty sure the reds are stronger.
It depends on state of tune which you want.
:wink:
PostPosted: Thu Oct 26, 2006 10:15 pm
standard GT (Cooper S) air box
red are stronger (4.5 oz). So that will make piston rise slower yea?
PostPosted: Fri Oct 27, 2006 5:38 am
Well.. stronger springs will make it rise less, but the rate of rise is a function of the dashpot's oil viscosity.
Vizard recommends red springs in all cases for twin HS2 on a 1275S, modded or not. I reckon with blues they would be wide open too soon, then you have lost mixture control. :wink:
For a well modded 1275, twin HS2s are too small. :x
PostPosted: Fri Oct 27, 2006 8:39 am
thanks Kev.
