It is currently Sun Jul 20, 2025 11:30 pm
PostPosted: Fri Oct 20, 2006 10:11 pm
Yes camlube is OK if you can get it, but I find the MPZ stuff is too runny, and most is sitting in the oil by the time you start it. :lol:
I now use good old Castrol LMM Molygrease, it does the job. Good for engine building too, but NOT on the bores or rings... use oil there. :wink:
 Post subject: Camlube
PostPosted: Sat Oct 21, 2006 9:36 am
I will try and get the brand of the stuff Ian used last time...it was about as runny as prussian blue :!:
Good stuff...stuck like...well it was very good. I think Ian also used it to prime his oil pump....it was a fair while ago now :oops: :!:
PostPosted: Sat Oct 21, 2006 9:46 am
I think you will find that thick blue stuff is made by Lucas. I have seen it and used it but cant remember its name - very sticky and gummy but a very very low co-efficient of friction.
PostPosted: Sat Oct 21, 2006 12:41 pm
Hi guys,
I've used the cam lube that came with the cam from the engineers. I'll post a reply here of its composition or whatever - should be on the tube in tiny writing that cant be seen!!!
Anyway, back on track, should I purchase a brand new set of lifters??
Cheers :)
Rod Image
PostPosted: Sat Oct 21, 2006 12:50 pm
Rodney wrote:
Hi guys,
Cheers :)
Definitely, IMO. Unless you want the risk of trashing your nice new cam.... :lol:
PostPosted: Mon Oct 23, 2006 9:08 am
Thanks Kev......I'll get a set this week.
Rod Image
PostPosted: Tue Oct 24, 2006 9:49 am
Phoned minisport, over in Adelaide and a nice new set of lifters will be in my possession within 48 hours.
So, "for sale' one almost new set of lifters :lol:
Hooroo
Rod Image
PostPosted: Thu Oct 26, 2006 9:57 pm
New set of cam followers arrived today and they're coated in some greasy substance - do I just soak them in oil and put the cam grease on the ends before installation, or do I clean this sticky 'goo' off of 'em first?
Thanks
Rod Image
PostPosted: Thu Oct 26, 2006 9:58 pm
clean them up first. :wink:
PostPosted: Thu Oct 26, 2006 10:01 pm
Thanks Kev. As per usual, you're the wealth of info. :D
Rod Image
PostPosted: Thu Oct 26, 2006 10:03 pm
Put the cam lube all over the cam as well. :wink:
PostPosted: Sat Oct 28, 2006 10:31 am
As promised, here's a pic of the tube of cam-lube that came with the freshly re-ground cam shaft. It's a small tube - no bigger than your thumb. Needless to say, there's none left!!!
There's no tiny printing on the tube to say what composition or whatever, unfortunately, but it's bloody good stuff.
Hooroo
Rod Image
