It is currently Sat Jul 05, 2025 5:37 pm
 Post subject: cooling setup
PostPosted: Mon Oct 02, 2006 5:35 pm
hey guys
1310 coming my way in about a week, wandering what sort of radiator to have, 2,3,4 core, is 4 core really worth the extra buck, can anyone recomend an electric water pump, driving i will be doing is mostly country roads but atleast %20 stop start,
PostPosted: Mon Oct 02, 2006 7:12 pm
Elec water pump try a davies craig one...
Life's a garden.... Dig It!
PostPosted: Mon Oct 02, 2006 8:08 pm
i dont think they had one small enough,
PostPosted: Mon Oct 02, 2006 8:30 pm
Use a morry 1100 radiator. They are a bit bigger (longer at the front) and have no problem fitting in a clubby. Ya gotta bash the top tank a bit to make em fit in a roundie.
PostPosted: Mon Oct 02, 2006 8:57 pm
I run a 2 core in Barney (1293A+) and a UK 3 core in my 1360 (with a `matic freshair heater).
2 core is not bad, but the UK rads are just not as well built as the Oz ones-
My UK 3 core shook the front support off the top tank in 2 weeks. Oz ones have rivets there, but UK ones are just soldered. :cry:
So, shortly I'll rip it out and fit a recored Oz one, with the tap in the bottom. Another thing wrong with UK ones... :evil:
PostPosted: Mon Oct 02, 2006 9:05 pm
go to your local radiator guy and ask them to make up a 3core CT type core and fit it to your noraml tanks. shouldnt be much more than $200.
great for modified raod cars as i have compared between uk 2core and a local 3 core and 3 core is much better.
cooling area is the same but slows the water down more to allow it to cool on its way thru the radiator.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Mon Oct 02, 2006 10:06 pm
what is the core, is it just an exspression or is it the sump looking thing on the top and bottom or the rad
PostPosted: Mon Oct 02, 2006 11:26 pm
`core' is the actual radiator bit between top and bottom tanks, with fins across it and tubes thru it. :wink:
PostPosted: Tue Oct 03, 2006 8:55 am
I'm running with the extra clubbie heater core.
Temp is good,but still does not like sitting at the traffic lights for tooo looong.
PostPosted: Tue Oct 03, 2006 1:57 pm
Nice engine bay..I like the carbies!
PostPosted: Tue Oct 03, 2006 3:01 pm
If your talking about a daives craig pump not being small enough, they also make a elec controller to up or down the temp (it must up or down the flow). Now last time i looked the smallest pump they made was an 80L per minute pump, but now? Best bet is to either call them or check out the website i guess
PostPosted: Tue Oct 03, 2006 9:35 pm
Yes I'm keen to keep with the SU's(1 3/4 set-up with Maniflow inlet manifold).
I just like em :D
PostPosted: Tue Oct 03, 2006 10:44 pm
hey LS, is that 2 or 3 core, nice engine bay, nice and clean, better than mine was i had a engine that was painted pink 20 years ago, paint under the bonnet was either body deadener or primmer, wriring everywhere,
has anyone had one custom made from aluminium
PostPosted: Tue Oct 03, 2006 11:59 pm
nothing wrong with the standard setup, I like the plastic 16 blade fans, and use spacers to get the fan as close as possible to the radiator - I reckon that's the key to a cool running mini, if the fan is too far from the rad, you're pushing crap uphill from the start
I did run an electric fan and clubman heater core in the engine bay on a couple of my previous cars, my cooper now doesn't get over 1/2 on the guage no matter what the conditions are, and it usually sits on the C mark - it's exactly as it came out of the factory except for the beefy motor ;)
