It is currently Fri Jun 27, 2025 2:12 am
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sun Sep 03, 2006 1:15 am
Yeah Gadget use gasless, my Mig is dually but try with the gas and couldn't get a decent bead and too lazy to persevere. Will get it done someday but a the mo the gasless while producing a bit of spatter give very good results for me. As for brand etc I will have a look tomorrow and PM you.
PostPosted: Sun Sep 03, 2006 2:01 am
Resident Haemorrhoid
thanks
that would be appreciated
mtsmini wrote:
Tombo wrote:
PostPosted: Wed Sep 06, 2006 8:29 am
Well guys finished the manifold. Could have spent hours grinding down welds but decided just to finish it and paint it. It goes on the car tonight.
PostPosted: Wed Sep 06, 2006 9:18 am
WILL WORK A TREAT... I think its fantastic.... DAM you do good work!
Baracade
PostPosted: Wed Sep 06, 2006 9:37 am
Thanks Bara coming from a man who knows good work that means a lot. Cheers. Can't wait to see what difference it makes especially with the uprated turbo. Next the intake pipe!!!
M
PostPosted: Wed Sep 06, 2006 12:48 pm
well done , :) What a work of art
im inspired to make my own soon
57 Morris minor
88 Rover Mini
PostPosted: Wed Sep 06, 2006 1:04 pm
Well done Matt.
First pic looks a little freaky. Doesn't look real, looks look its a CAD drawing.
PostPosted: Wed Sep 06, 2006 3:13 pm
Stripey yeah especially that first one. I got a sanding disc attached to my drill and it made the edges really cool. I could have spend much longer making the welds etc look reall smooth but in a number of places I have read not to grind welds down as it weakens the welded joint. I will put the thing on tonight and attach the turbo for the last time which will be a real milestone. Anybody have ideas on lines kits for turbos I have one lined up with ModYourCar but it is $280 (all braided) but I was wondering if there was a suitable cheaper alternative.
PostPosted: Wed Sep 06, 2006 4:20 pm
Top job Matt.
As far as smoothing the welds you can buy special flap sanding disks for your 4inch grinder, they work a treat. I don't think you would weaken your welded areas to much as the elbows have the 45 chamfer on them and that allows the weld to virtually fill the full thickness of your tube. I chamfered my straight steam pipes too so that i could get as much weld into the joins before grinding.
As far as lines for the turbo i went down to the auto shop and bought rubber hose for the water lines, cost $10, two nipples for the turbo from pirteck $35, Oil feed line (fuel line or petrochemical resistent line) $10 and Oil return line, again a oil resistent line for $20. Total $75 bucks. Keep in mind my turbo is further away.
Once again top job.
Dan
PostPosted: Wed Sep 06, 2006 7:36 pm
Bloody good work there, i'm impressed! 8)
PostPosted: Wed Sep 06, 2006 11:00 pm
Minime you may have a point. Pirtek for the nipples yeah! Anyway bolted the turbo to the manifold for what I hope is the last time. Bought some new nuts for the manifold studs but were wrong thead. Anyway last pic I promise... :D
M
 Post subject: Grrrrrr
PostPosted: Wed Sep 06, 2006 11:08 pm
Matt....I can feel the ground shaking from here mate....the flap wheels sound the go for cleaning up the welds...but only for bling, not for GO!!!
Let me know if you are going to MDU (by yerself)....room available :shock:
PostPosted: Thu Sep 07, 2006 11:57 am
looks a treat if you had a good shuamfer on it you should be able to grind it but its not going to make it go faster so why bother top job
PostPosted: Thu Sep 07, 2006 12:53 pm
I'm impressed, you did it so quickly and it looks great. who cares about the finish it's one of the best proper home made headers I have seen for a while
and a few conversions:
13B Extend in a 1600
PostPosted: Thu Sep 07, 2006 2:18 pm
Yeah Hugh I could of spent several more hours grinding and polishing but I though F I that'll do. And I kind of like leave it looking workmanlike. And my main objective was FLOWWWW. 8)
M
PS. That's why I said come around Sunday as I had a fair amount done and you could have seen something... :wink:
