From the good book for the front follow the instructions in the pics.
i used this to jack the front of mine up and place the stands. you can put the stands either end of the block of wood, or under the flat part of the subframe.
for the back the book says to jack it in the middle of the rear crossmember of the subframe. I put the stands under the flat part under the suspension cone, or at the outer end of the rear crossmember.
remember that the further outboard you can place the stands the more stable it is.
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
