striped 63 wrote:
Your engineer should be asking for disc brakes equivalent to that of the donor vehicle.
I see your point, if the vehicle were the same weight. My father is a mechanical engineer, he consults from OEM manufactures like ford, MB, Kenworth, Mack, Hino etc. That is how i have drawn my conclusion. When talking about brakes, aslong as you are off the gas when appliying brakes (which you should be), you are talking about the weight of the vehicle, OD of the tyre being used, weight bias, etc etc that are the contributing factors. If you motor has 75 or 200 Hp doesn;t make any difference to how the car brakes in a emergency situation.
Up here in Qld they are very laspe on conversion rules anyway, many 808/rx3's get approved with 400+HP turbo rotaries and std brakes
. I know i'm in it for my safety aswell as others, but i'm confident that Cooper S disks with the right booster/pad combo will pull the car up better than mots others on the road.
