It is currently Mon Jul 07, 2025 8:34 pm
PostPosted: Tue Jul 04, 2006 9:30 pm
I want to run twin 1.5 inch Su carbs, much like the works coopers and the Oz police cars from the 60"S.
Have the carbs linkages etc but need a twin Su manifold that works. Does anyone in OZ do a twin su inlet manifold to fit 1.5 inch carbs square flange
I have a 1300 gt Land crab one which has been modified from 1.25 to 1.5 inch but it does not look like the best
Bernard.
PostPosted: Tue Jul 04, 2006 11:03 pm
Lynx did make one here for twin 1.25s, they are still common but won't fit 1.5s unless you use the real old H4s.
Redline still list one new, but only for twin 1.25s.
Only manifold I saw here for twin 1.5s was the square flange factory Mk2 S one, Minispares UK do one similar.
Try also SU Midel in Sydney. http://www.sumidel.com/
Best one for flow supposedly is the Maniflow steel, available from Minispares etc.
PostPosted: Wed Jul 05, 2006 1:11 pm
There is one for sale on Ebay at the moment.
http://cgi.ebay.com.au/Mini-LYNX-carby- ... dZViewItem
Pete
PostPosted: Wed Jul 05, 2006 7:46 pm
.....Yeah but that one won't fit a matched LH & RH pair- you would need to use a bit of rod and 2x `W clamps' to link the throttles.
Nowhere near as good as the proper SU linkage.
PostPosted: Wed Jul 05, 2006 7:52 pm
Thanks for the info so far
I thought the Maniflow one is suppose to be the best
Unfortuntley i have not seen one or had any one use one here in NZ
B
PostPosted: Wed Jul 05, 2006 8:25 pm
If all else fails get someone with enough time and experience to make you a custom manifold. Correct if Im wrong but that is a possibility but expensive too.
PostPosted: Wed Jul 05, 2006 8:35 pm
I could actualy make one myself have the resources and friends but zero time with a young family.
I would like to have a maniflow one to work from if i made one up.
don't want to re invent the wheel so to speak hence my posting
PostPosted: Thu Jul 06, 2006 9:41 pm
B
I got mine direct from Maniflow in UK.I've just found the reciept.
I emailed them([email protected]) then paid by credit card.
Part number for twin 1 1/2 Inlet is L149-2XHS4-1.5.I also ordered matched port to head.
Cost(2004) Pounds 95.00 postage 15.00-Total 110.00(pounds) landed in Aust.
No VAT to pay because export order.
Hope this helps.
http://i52.photobucket.com/albums/g25/L ... dLS002.jpg
PostPosted: Fri Jul 07, 2006 7:52 pm
thanks for the photo.
was it straight bolt on affair or did you have to modify it in any way as your one has a provison for the accelarator cable and the ones on the website don't.
Also can you remember what needles you are running as i am also building a big bore engine 1360
B
PostPosted: Sat Jul 08, 2006 9:25 am
Yes straight bolt on job.Briazed on the cable attachment,then got the manifold coated before fitting.As for the needles,not sure as I had the motor dyno tunned and the guy kept putting the needles in his lathe until he got it right...I'm more than happy with the set up(these are now twin 13/4) as 1/12 were not delivering enough fuel and air!! I decided to stay with yhe SU set-up instead of sticking a Weber on it. :)
PostPosted: Mon Jul 10, 2006 4:51 pm
I had one made by maniflow (but for twin 1.25" HS2s) and simply asked them to include the throttle cable bit. They did, no extra charge. I can email you some pics if you like.
Go straight to maniflow and start asking them questions, then once you are happy, send em your credit card number and 2 - 3 weeks later a special package will arrive on your doorstep. :wink: :D
PostPosted: Mon Jul 10, 2006 8:08 pm
Mat68 i would like a photo of your manifold.
I tried going onto the Maniflow website did not have much luck.
Thanks
B
