It is currently Sun Jul 06, 2025 2:04 pm
 Post subject: S rods vs. Non-S rods
PostPosted: Fri Jun 30, 2006 3:03 pm
Hey guys, can someone tell me if non-s rods are going to be strong enough in my stroker build? Lookin at 120hp maximum. Do i really need to source the S rods, or can i get the others balanced and lightened etc?
2002 TopKart Viper with Blueprinted Yamaha KT100S @ 17hp. 160kg.
PostPosted: Fri Jun 30, 2006 3:26 pm
Oh never mind, AEG177 are infact MK.I S rods. Anyone got a spare?! Will swap for AEG521... See post in wanted... which is exactly the same. :P
PostPosted: Fri Jun 30, 2006 8:35 pm
Just check they are all the same weight if you have to mix them. :wink:
PostPosted: Sat Jul 01, 2006 11:57 am
Kartbro,,,if you have a set of 521s then use them, they`re stronger than the 177s
PostPosted: Sat Jul 01, 2006 10:37 pm
Isn't there a problem with 521's and the camshaft in a stroked motor. Which is why 177's are needed.
PostPosted: Sun Jul 02, 2006 8:56 am
Most strokers here in Oz I've seen were done using 521s- are you sure it's not the 8 port Arden head (with its funny cam lobe assignments) that causes the prob when stroked? maybe.... :?
PostPosted: Sun Jul 02, 2006 7:24 pm
Smiffy,,,i`ve been doin strokers for over 20 years,,,allways use 521s
my 1510cc stroker donk has crank offset ground to .080thou undersize & has 521 rods, that`s quite a big stroke --->(but that`s just what all the girls tell me :-) )
PostPosted: Sun Jul 02, 2006 7:27 pm
yeah yeah :roll: :P
PostPosted: Sun Jul 02, 2006 7:39 pm
:P refers to the stroker donks that he builds which are quick
and :roll: to the girls comment :lol:
PostPosted: Sun Jul 02, 2006 8:10 pm
You measure your stroke in thousanths of an inch? Strange girls is all I can say :twisted:
PostPosted: Sun Jul 02, 2006 8:57 pm
Come on guys it was a question, one which im quite pleased about your answers, as I do have a set of 521's in storage for a rainy day.
PostPosted: Wed Jul 05, 2006 10:55 pm
Now zizzle,,,you`ve gone & rained all over my parade :-)
yeah, use the 521s Smiffy, no problemo.
