Simon,
I had a similar prob with my boss's (mate's) 1275LS he bought a year ago.
It had clutch slip under slightest provocation, even though motor was very tired- but when I took it apart the plate (Borg & Beck) was almost new- wear was about 0.5mm only.
I did a trial build on it with a new plate, the diaphragm was nowhere near flat when assembled.
I had to machine 1.5mm off the 3 lugs to get it right. Works well now.
Whoever had worked on it in the past had machined both the flywheel face and the backplate numerous times, but left the 3 lugs...
See Chichm's analysis of clutch building, here-
http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
Works for me- I'm running an orange plate now, it grips well and pedal effort is lighter than my old blue plate was.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
