It is currently Fri Jul 04, 2025 4:10 am
PostPosted: Wed Jun 21, 2006 8:25 am
Ok what is in your opinion a good recipe for a good rear set up (DRY subframe)
PostPosted: Wed Jun 21, 2006 8:37 am
Hi Lo's with a adjustable Shocks replace Pins, Knuckels and Bushes
PostPosted: Wed Jun 21, 2006 8:43 am
any brand
PostPosted: Wed Jun 21, 2006 8:47 am
Shocks ? My fav has always been Koni but opthers have thier own preferances
PostPosted: Wed Jun 21, 2006 10:20 am
and adjustable camber & caster brackets.
 Post subject: mm1275
PostPosted: Wed Jun 21, 2006 6:48 pm
KONI Yelolow shocks
HI-LOW cones
Springs replace the rubber cone
Camber and toe in adjustable arms.
Here is the rear suspention setup on the Black car.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Wed Jun 21, 2006 9:51 pm
I'm gonna give a set of Bilstein shocks a go.
PostPosted: Wed Jun 21, 2006 9:53 pm
those springs look trick whats the advantage and cost
PostPosted: Sun Jun 25, 2006 5:51 pm
if u r putting those springs in y not consider a set of coil overs??
PostPosted: Sun Jun 25, 2006 6:04 pm
Kayaba (KYB) """Gas Adjust""" are great for road/rally use
very very good shocky indeed
& yeah , of course reco arm pins etc & Hi-Los, But you can easilly just set your rear brakets up on the wheel alignment machine to point the wheels where you want them, no need for adjustable brakets really,
those coil springs are not really a necessary item, good bling factor tho.
