It is currently Fri Jul 04, 2025 10:27 am
 Post subject: A+ Engine
PostPosted: Thu Jun 01, 2006 10:57 am
Hi all
What year did the A+ engine come into existence in minis and mokes?
Is their a cut off year between the A series & A+ series?
Is there A series 1275 motors as compared to A+ series 1275 motors?
PostPosted: Thu Jun 01, 2006 11:24 am
its a mixed thing really, australian mini's never got a+ but the uk 1275gt got a+ block arround 1979, these cars were a mix of parts, usually a+ block and gearbox but non a+ head. from what ive read most of these ars went export(not uk home market), after the gt ended production in (1981?) it must have dissappeared from minis till (1990? ) when the cooper was released. 81 - 90 it was still being used in the mg metro and metro VDP and the (montego/mastero 1300?) (not austin metro)
The 998 a+ came in mis 80's sometime...i think
so no, it didnt kinda come in overnght, im not sure about the moke though.
PostPosted: Thu Jun 01, 2006 12:15 pm
In Aus later Mokes, post 78 until the end in 82, had A+ gear boxes but original A engines.
All Australian delivered minis and Mokes had A engines, not A+.
In the UK the 1275 A+ engine disappeared out of mini production, but continued in Metros during the 80s until minis once again got 1275 engines in 1990. I believe all metro engines were A+ until they changed to K-series.
PostPosted: Thu Jun 01, 2006 12:18 pm
im sure the lower range metros never got the a+ :D
PostPosted: Thu Jun 01, 2006 12:21 pm
Not the 1275 A+ but I was pretty sure they had the 998 A+
PostPosted: Thu Jun 01, 2006 12:24 pm
fair call, dunno about the 998, when did that come into production? wasent in minis in 82, so i assume 84 allong with the discs?
PostPosted: Thu Jun 01, 2006 12:47 pm
MY 81 moke has A+ gearbox and I presumed A+ 1275 motor.
I presumed this because it has an A+ dist drive.
engine no 12H706AA7032314
PostPosted: Thu Jun 01, 2006 12:55 pm
yup, thats a 1275 a+ then, probably dosent have an a+ head though, is the area behind your themostat housing flat?
:D
PostPosted: Thu Jun 01, 2006 1:00 pm
Location: Melbourne, Australia (car); Savannah (GA), USA (me)
I disagree. I have two 1980 Mokes with their original '12H' motors. They are both A+. Dead give-away on the A+ is the dizzy and the timing cover vent.
PostPosted: Thu Jun 01, 2006 1:06 pm
and the ribbing in the front of the block....anyone got an a+ head :D they are sculpted behind the thermostat insted if flat...
PostPosted: Thu Jun 01, 2006 1:07 pm
interesting i have a 1275 A+ motor in my 77 clubman s i was told this by a reputable mini shop.. and i think its the original motor. how can you tell its a A+? and the area behind the themostat housing is flat. also my themostat housing points towards the back of car which is different to other minis i have seen.
S.M.R
PostPosted: Thu Jun 01, 2006 1:11 pm
whats the engine number? and is the dizzy held in by a "fork" or a clamp? also the area on the front of the block is ribbed on an a+. 77 clubman would NOT hav had a standard A+, or a 1275 for that matter.
oh, 1275 thermostats point a diff direction to smallbore ones...pain in the....
PostPosted: Thu Jun 01, 2006 2:34 pm
Barney now has a 1293 A+ motor in, came out of an 81 Oz Moke.
Not sure what head it had originally but it's wearing a 1275LS one at the moment.
Modified, of course..... :P
PostPosted: Thu Jun 01, 2006 2:37 pm
:D well we wouldent expect anything less from you would we :D
PostPosted: Thu Jun 01, 2006 4:54 pm
I've got the A+ dist drive dog, a vent can on my timing cover.
What sort of ribbing does an A+ head have?
Anybody got a pic and on that subject how do you insert a pic into your message?
