I got the subframe from dennis turner (built twincamminis frame) i had to reinforce the front tie bar mounts and change the engine mounts, but yeah i got it pretty cheap, thanks dennis
hehe
brakes, camira calipers and rotors?? calipers $40 for 2, rotors $26 trade price each, my mate whos a aprentice fitter and turner, he made the brackers and spacers , bought him a carton of piss
he also made my axles
price $0
difficult, not really, bit of motivation is all you need, fuel lines and brake lines, fidly stuff like fitting the instrument panel and all the other stuff was time consuming..
for someone like me it was a good conversion to do, cheap subframe, cheap donor car $600, available tools from work etc.. and i was able to take the car to work for a week to work on it which made it a lot easier..
it cost me under 3 grand to do the conversion to NA .. all the little things added up.. the brakes were most expensive, dual master, prop valve (reco'd) new booster, lines etc came to about $800 .. the donor car, $600 , subframe was cheap.. new clutch, waterpump , timing belt, engnine mounts, number plates fuel pump, lines, air cleaner intake, exhaust, small wiring job (indicator stalk and wipers) rego and few other things
id recomend doing an NA conversion, i wish i left it na, i spent $5 grand turbo'ing it , wheels, turbo, cooler, exhaust, piping, new crank, pistons, rings bearings etc, fuel reg steering wheel, guages, tacho, oil and boost and cant remember other stuff but added up quickly..
hope thats enough info
