It is currently Fri Jul 04, 2025 10:01 am
PostPosted: Mon May 22, 2006 8:54 pm
put comp rear bumps stops in my hydro car and now it is as high as a 4X.4 can i cut them down about a inch or will it defeat the hole purpose of having them.
PostPosted: Mon May 22, 2006 9:57 pm
It means you need to pump your hydro up... It has nothing to do with your ride height. If your car is sitting on your rear bump stops then your hydro is way too low...
I noticed Lillee's handling and overall ride increased considerably when the hydro was pumped up.
Also make sure they aren't sitting on the body the body "flange" thingy that sticks out. I had to bend mine out with multigrips...
PostPosted: Mon May 22, 2006 10:19 pm
No Chong,
They are tall as they are designed for the car to sit on, but they will settle a bit after a while. Mine sits pretty level now with full tanks.
They are really progressive springs, not just crash stops like the originals. I wouldn't cut them down, Stuart, or they will be useless.:wink:
Last edited by drmini in aust on Mon May 22, 2006 10:41 pm, edited 1 time in total.
PostPosted: Mon May 22, 2006 10:23 pm
Hey??? Mine are like 2-3cm between the bump stop and body at normal ride height? they don't sit on the stops 100% of the time do they? in that case my hydro is too high?
PostPosted: Tue May 23, 2006 12:16 am
Your hydro is probably right, just the retainer springs at the back could be worn, not balancing the hydros right..
PostPosted: Tue May 23, 2006 6:24 am
has anyone got pic's of these fitted? wonderin if i can fit them to the 1300...... :lol:
PostPosted: Tue May 23, 2006 8:57 am
Yes after discussing with Doc last night we came to the conclusion that the car should not be sitting on the bump stops 100% of the time. If this is the case then 1) your hydro is a bit low, meaning the back sits on the bump stops making the front lean forward, 2) your helper springs are worn 3) the bump stops need to settle in abit and will compress slightly with time.
On that note I had this exact same problem when they were first installed, the car leaned forward quite a far bit. After a hydro syste flush and repumped and alot of greasing up of the rear arms and front arms, this has settled down. Now Lillee is even front and back, no more forward lean... Make sure you grease those nipples! :wink:
PostPosted: Tue May 23, 2006 5:09 pm
i just took them out and put the old ones back in. i will put the comp ones in if i wanna hit the corners hard though.
Users browsing this forum: No registered users and 25 guests
