It is currently Fri Jul 04, 2025 5:23 am
PostPosted: Wed Mar 22, 2006 11:47 am
I have a pair of hubs and want to replave the top and bottom ball joints
what size socket is used to remove the big nut. the largest spanner I have is 1 1/8 so I will go out any buy a new one
PostPosted: Wed Mar 22, 2006 12:29 pm
i use a very large adjustable, although the las one i did was rounded(probably from said larg adjustable) so i used a pipe wrench and a jack handle, resulting is sore knuckles and a bent jack handle.....but th lil bugger came off :lol:
PostPosted: Wed Mar 22, 2006 12:47 pm
Go to Paddy's markets or the like and buy a deep impact 1&1/2" AF socket. Anything will do as you will NEVER break it doing what you are doing. Mine was made in good ol India and it was $18. It will most likely be a 3/4" drive so you may needa 3/4" to 1/2" drive converter to fit your 1/2" ratchet.
Undoing it is easy, but you really need a torque wrench to do them up properly to the correct torque setting so that you can accurately shim the ball joint for correct tightness...
Don't forget to knock the lock tabs down and knock them back up when you're done :shock:
Lillee - 1969 Morris Mini K
 Post subject: aaa
PostPosted: Thu Mar 23, 2006 9:15 am
Thanks guys
I used a shifter an a section of pipe to remove them. and I rounded one of the nuts. 1 1/2 is the size then
thanks for your help
PostPosted: Thu Mar 23, 2006 10:20 am
I used a pipe wrench from the start, cause it was big enough for plenty of leverage and it tightens the more you pull, as opposed to a shifter which loosens, resulting in round nuts.
PostPosted: Thu Mar 23, 2006 11:03 am
and here was me thinking....i probably shouldnt do this with a pipe wrench.....(other un publishable thoughts also flowing...)
