It is currently Thu Jul 03, 2025 4:28 pm
 Post subject: Starting Mods
PostPosted: Tue Mar 14, 2006 1:28 pm
Hi,
Ive got a 998 cc engine that i recently had bored out 40 thou and has been rebuilt. Its got an RC40 exhaust and extractors. The camshaft and rockers are standard, but the valves have been changed to run on unleaded.
I plan to use it in hillclimbs and possibly rallying. Can you tell me what engine and gearbox mods would be best to do.
Thanks.
PostPosted: Tue Mar 14, 2006 1:52 pm
Replace the standard 998 head and get a 12G202 or 12G295(if you can find it) or you could pocket the block and use a 12G940 big bore head.
Are you restricted in the capacity(cc) that can run ? if not you can stroke the engine by fitting a 1100 crank and pistons.
If you are not restricted you are probably better off looking at getting a 1275 engine as these will be easier to get more horses out of :wink: initially more expensive but as you try to get more and more power it's probably the better way to go :wink:
have a look at:
http://www.ausmini.com/forums/viewtopic ... hlight=998
Roads need more corners
PostPosted: Tue Mar 14, 2006 1:56 pm
how does it stop and turn?
PostPosted: Tue Mar 14, 2006 3:48 pm
Yep 1100 Crank, better Cam, fighten the Flywheel and sme head wrk dne on a 202. also depending on what Carb you are running now I would up grade that also
Ow and A pulsar dizzy..forget the points..
PostPosted: Tue Mar 14, 2006 6:21 pm
put a performance cam in , electronic ignition and double valve springs, oh and make sure your carburettion is good enough
if you want an 1100, buy one, don't ruin a perfectly good 998 8)
PostPosted: Tue Mar 14, 2006 6:48 pm
Yeah Kartbro is selling an 1098 block, crank, rods and pistons for cheap. PM him.
He also is selling a 12G295 head too or extra vroom 8)
