It is currently Fri Jul 04, 2025 10:05 pm
 Post subject: Ride Height
PostPosted: Thu Mar 02, 2006 7:59 am
Righto, so i've got rear Hi Los (only), That's nice, it's different, it's unyooosual.
What would be the best height to set it to for handling purposes
Considering I've got stockie shocks, and i don't have hi lo's on the front.
What's the best way to measure ride height? From ground to Wheel Arch, tire to wheel arch..etc...
PostPosted: Thu Mar 02, 2006 8:05 am
How often do you carry people or stuff in the back ? Basically find your favourite "mini suitable" road and have a good thrash on it . Keep lowering the rears bit by bit until they start bottoming out on the corners and then put them back up a smidgen .
PostPosted: Thu Mar 02, 2006 8:18 am
no seat belts... so no one.. ...well... except william.. :)
is there a less trial and error method?
PostPosted: Thu Mar 02, 2006 9:02 am
Till they look level and look good . It all depends on how good your rubber cones and shock's are . Put it at a level that you think looks good and give it a thrash and see if it bottoms out .
PostPosted: Thu Mar 02, 2006 9:21 am
it's all pretty much new out the back....
guess i'll just leave it :)
if it aint broke.....
PostPosted: Thu Mar 02, 2006 9:23 am
something like that , give it all time to bed in as well and then see what you think with it , lower it if it still feels a little high .
