It is currently Sun Jul 27, 2025 8:47 pm
 Post subject: Steering rack
PostPosted: Mon Jan 30, 2006 8:38 pm
My steering rack has developed a knocking noise from the pinion housing assembly. When the car is jacked up and you rotate the rack you can feel the knocking noise through the assembly. I believe this is due to excessive play in the housins assembly. I read someware that you can take off the end cover and remove shims to adjust any excess play is this so ?
http://photobucket.com/albums/v515/chasg/
 Post subject: Re: Steering rack
PostPosted: Mon Jan 30, 2006 8:49 pm
Go and get an exchange rack....unless you really know what you are doing it just ain't worth the possibility of losing your steering :idea:
