It is currently Mon Jul 07, 2025 5:16 pm
PostPosted: Mon Jan 23, 2006 10:35 pm
Hello all,
I am after some one who knows how to tune a weber....
My problem is that:
It smokes, coughs and I am getting fire in the air filter
PLEASE SOMEONE HELP ME
I was hoping to have the car tuned by thursday at the latest but if not it has to be friday
PLEASE SOMEONE ANY ONE HELP
Thank you
My Purple Boom Box - Now Consists Of:
Kenwood Head Unit, Kenwood 800w amp, 2 Kenwood 6" 200w, 2 Kenwood 6x9's 400w, 2 Kenwood 10" 900w. It Awesome.
:twisted: Plus All The Neons
(well used to be / soon to be again)
Regards
Ryan
PostPosted: Tue Jan 24, 2006 7:41 am
Well if you get desperate to have it running again, just put your SU back on.
What sort of condition is the webber in? I mean if it needs rebuilding and you havent done it, I'd look at that first.
PostPosted: Tue Jan 24, 2006 8:44 am
Hi
No the weber was rebuilt by the owner before me not too long ago so it not that and the SU is just a real pain
But thank you
Regards
Ryan
PostPosted: Tue Jan 24, 2006 8:49 am
Has the Weber been running on your car before or is it a being set up for the first time :?:
If it's the later, then you'll need to start at Square One by getting the chokes, auxillaries, emulsions and jets all set up for your engine. Once you're in the ball park it should run OK, but you'll still need some fine tuning on a dyno to get it 100%.
If it's been on your engine before, and now playing up - try removing and cleaning the idle and main jet units, remove the mixture screws and blow some air or carbyclean down the passages.
Curly
PostPosted: Tue Jan 24, 2006 8:51 am
My very limited experience with webers says if it is spitting out the filter then it is probably running too rich. :wink:
See if you can do anything with the mixture screws but if that doesn't do it then it will probably need rejetting my advice would be take it to someone who knows how to tune webers and has a selection of jet and they should be able to what jets to put in it otherwise you could end up buying quite a few jets before you get it right.
Here's a couple of links about webers:
http://www.teglerizer.com/dcoe/rasorcom.htm
http://www.tjwakeman.net/TR/WeberDCOEinfo.htm
Roads need more corners
PostPosted: Tue Jan 24, 2006 8:54 am
Hi
I bought the carby from a guy that had it fitted to an 1100 same as mine but his was a stock mini mine has had some work done and is just not right
but thank you for your advise and help
Regards
Ryan
PostPosted: Tue Jan 24, 2006 9:20 am
hello
thank you for the links they were real helpful if a bit long but if they help then it will be worth reading
once again thank you for your help
Regards
Ryan
