It is currently Sun Jun 22, 2025 12:45 pm
PostPosted: Mon Jan 16, 2006 11:24 am
i am considering just grinding the nutt off and then seeing if i can slide the aircon unit off over that...is this a bad thing to do? someone has rounded off the nut on it during a previous install...
its the one you can see below the red (momo corse) oil filter...
here's a closeup:
Bling me up Scotty!
PostPosted: Mon Jan 16, 2006 11:29 am
It's your call, but I would remove the oil filter & use a pair of Vise-Grips
PostPosted: Mon Jan 16, 2006 11:36 am
the position of the oil-filter isnt actually a problem...i can get spanners and stuff in there without any trouble...
hmmm...vise-grips...not a bad idea...the only prob is that there's almost no working room...i'll make a stop in at the local hardware store to see if i can get a pair this arvo...might do the trick...if not...its angle grinding time...
Bling me up Scotty!
PostPosted: Mon Jan 16, 2006 11:39 am
Or you could usse a Metrich spanner, will remove rounded nuts.
Or just grind through the nut untill you almost reach the thread and the you will find it will come of fairly easy after that.
Or just chop it off. You wont need it.
Dan
PostPosted: Mon Jan 16, 2006 11:49 am
cool thats good to know...i'll see if i can get a metrinch spanner from the hardware store near me...
Bling me up Scotty!
PostPosted: Mon Jan 16, 2006 1:30 pm
Can try giving it tap with a chisel too. See if you can get it to turn.
PostPosted: Mon Jan 16, 2006 1:48 pm
The TIG
Use a pipe wrench (I'm sure you guys have much better word for it and will make fun of me.) that will get it off way better than vise grips as long as there is room for one.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Mon Jan 16, 2006 2:52 pm
Stillson
or monkey wrench to you Yanks :P
There, happy now? :lol:
PostPosted: Mon Jan 16, 2006 3:06 pm
managed to source a 12mm metrinch spanner that should be arriving tomorrow via post (total cost $20 inc. postage...ick)...if that doesnt work i am gonna take the grinder to it...too much time and money on 1 bolt that i dont even need...
Bling me up Scotty!
PostPosted: Mon Jan 16, 2006 3:42 pm
If you take the grinder to it how about grinding some flat sides to the nut and then trying a spanner on it :wink:
Roads need more corners
PostPosted: Mon Jan 16, 2006 3:48 pm
coz that's too tricky...might as well just take the whole thing off...there's limited room and i cant be bothered frigging around with trying to grind tiny bits off it...would rather just nuke it...
Bling me up Scotty!
PostPosted: Mon Jan 16, 2006 6:52 pm
can't you fit a DEEP 12mm single hex socket in there? 3/8 drive, of course.. :wink:
PostPosted: Mon Jan 16, 2006 8:19 pm
dont have one of those...just got a normal socket set...
Bling me up Scotty!
PostPosted: Tue Jan 17, 2006 10:53 am
The TIG
I'm no Yank. I'm Canadian eh!
PostPosted: Tue Jan 17, 2006 11:03 am
:lol:
I though you were going miss that one. :wink:
