GeoffP wrote:
re the filter, if it's the usual 445S type for 45DCOE the holes are not offset and so it won't fit on a Redline/Warneford manifold- it fouls the firewall.
(I'm running the smaller 440S filter with offset holes. I opened the 42mm holes out to 45mm and put a Finer Filter pad in it...
![Wink :wink:](./images/smilies/icon_wink.gif)
I've got the 445S filter and its jammed up hard against the firewall
![Shocked :shock:](./images/smilies/icon_eek.gif)
I thought thats just how they were meant to be
![Confused :?](./images/smilies/icon_confused.gif)
I think it causes a few extra rattles and vibrations, but apart from that does it matter?
I might have to get one of those smaller ones. any reason you use a finer filter pad and not the standard ramflo foam?
Yeah they have less restriction, and when you oil them with Finer Filter or UniFilter oil, they don't catch fire like my Lynx one did...
Apart from that, Finer Filter
were around the corner from where I used to work.
Not now- they closed up, got bought out by UniFilter I think. Dunno if UniFilter keep the pads in stock but I'm sure they can make them up!
I'd offset that 445 filter or change it, otherwise you are going to bust the manifold flanges...
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
