It is currently Mon Jul 14, 2025 11:52 am
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: GR head
PostPosted: Thu Dec 01, 2005 6:32 pm
i get my head back from Graham Russel this saturday so i will post some pics up for everyone. i was very disapointed with my performance at the dyno day (43.3hp) so with a little GR magic i should be a happy boy.
PostPosted: Fri Dec 02, 2005 5:55 am
Nice Work Stuart,,you will be very Happy with it :wink:
you wont get beaten by two 1100 next time :lol:
PostPosted: Fri Dec 02, 2005 1:50 pm
he got beaten by 4 1100's :wink: and 0.2hp more than my 1100
PostPosted: Sat Dec 03, 2005 5:55 pm
well i got the head and the cam back today. all looks really good. i also found when i stripped it down that one of the thrust washers on the reverse idler gear had welded itslf to the gear so that would have been causing a massive drain on power. i also have a rooted wheel bearing which would drain a fair bit too. so i'm hoping for big fugures. GR also solved my problems with the weber. i had set the float gap set to large and the air filter was over oiled which was doing all kinds of bad things. Graham said that with the small valves and the large ports he has seen 130hp so i can't wait to get it back on road. GR is a top bloke and i say it was money well spent and would recomend him to everyone. Next on the list is a stroker but that will have to wait a little while. i will post some photo's soon
PostPosted: Sun Dec 04, 2005 7:56 pm
ok the pics are here http://spaces.msn.com/members/stua54/
if some has th time can u post them up properly i can't do it
PostPosted: Mon Dec 05, 2005 8:47 am
GR did the head on my inlaws 1100....I can spot GR's work now, having seen a few of his heads.
PostPosted: Mon Dec 05, 2005 9:42 am
Noice! I can't wait to send my metro 1300 head to Graham to work some of his magic on :D
PostPosted: Mon Dec 05, 2005 11:15 am
JAM what did it cost to do the head with GR???
Cheers Gerard
PostPosted: Mon Dec 05, 2005 12:49 pm
it all depends on what u want done. give him a call and ask.
PostPosted: Wed Dec 07, 2005 4:43 pm
i dropped my redline manifold off to GR to get some work done but i am goin on holidays for 2 weeks so no work will be done on the car. i can't wait to get it back together thought i'm hoping for 70hp @ the wheels
PostPosted: Wed Dec 07, 2005 7:06 pm
It'll probably come back looking a bit like mine.... :twisted:
PostPosted: Wed Dec 07, 2005 7:13 pm
Show off :roll: :lol:
PostPosted: Sat Dec 10, 2005 12:56 am
"i'm hoping for 70hp @ the wheels"
Mate, it took me 12PSI and a HEAP of head work to crack 73@ wheels......
it was an absolute fire-breathing 1360 that only just took me out (first Ausmini Dyno day) and it managed 74.somthing on the day......
70@wheels, for N/A is a real stretch... Kev, what was yours.. around 68 wasnt it ? - you've have close to the hottest N/A engine woudnt you ?
I'm hoping to crack 85+ @ wheels in the next few weeks, then the next stage is over 100@ wheels.....
not a GR head, but a DRMINI ST head .......
J
PostPosted: Sat Dec 10, 2005 6:00 am
James,
I pulled 75.4HP with the 1360 last dyno day, but it was running a little lean.
GR got 79 from his 1400, and Ron had 81.? from the $13K 1440 motor.
Since then I've rejetted it and changed the cam to an RE282. Seat of pants says it is going much harder. Will put it on Mini Classic's rollers next week. 8)
<edit> Yep mine runs a DRMINI head too.:)
PostPosted: Sat Dec 10, 2005 10:16 am
Stuart, what size valves are you running in this head? Looks like a great head!
Mini - The Wizardry on Wheels!
